a hummm... new to powerstorke
hello, Well i did it just go my 1st powerstroke 1997 f-250. was that a step up or down from my 1994 f-350 idi anyway ... with the powerstorke i found that there is a humm that gets louder with higher RPM .. is that engine? or tranny? (auto) normal or not? and what tips are there with owning a turbo. i noticed the turbo only really spools at liek 2500, any way i can make it louder
Thanks
Dave Ford
Thanks
Dave Ford
lol ... good one ...
the sound .. well it kinda sounds like .. you know that sound when your in a front wheel drive car and its got a bad wheel bearing ... thats what i hear kinda . but its only really dominate at rpm or greater then 1700 i did it in park and in neutral same only thing i havnt tryed is transfer case neutral.
on
You might try removing the belt and run it. That will either rule out or point toward a idler pulley, alternator or other belt driven parts. Also does the down pipe coming off the turbo to the under truck exhuast look like 3 inch round or does it have a seam on each side and look flat. I am just wondering if the DP has been replaced (with 3 inch pipe) and its rubbing the firewall.
Received 3,690 Likes
on
LOL by the way- PMS = powerstroke modification syndrome...
In my opinion you made a step up. the IDI's are good engines, but the direct injection powerstroke (yours) is more powerful, efficient, etc.
The intake and exhaust will make your turbo spool much better. mine sings from idle to redline... and i love it...
Where are you from?
I cant help you with the sound, but there are plenty of guys that can. this is an awesome forum, and has a wealth of knowledge. Welcome.
Where are you from?
if it does it in any gear of the tranny, me thinks it's in the engine.
Are there any other symptoms that go with it?
what does the Oil pressure gauge say when this happens?
regular oil changes?
any check engine lights associated?
just trying to cover all the bases.
Do you have any way to check the fuel pressure? if so, what is it?
ok, truck starts mint, sounds good, no check engine light, pressure is good, oil is clean, fuel pressure unsure have no way of checking ummm.. what else, not sure what else to do, umm .... how would i check the waste gate? maybe the turbo? try doing it without with open airbox? umm ... i donno i got nothing .. boggling ..
weather in the bay just got a foot of snow hovering round -8
