Did I miss something or did you mean 08B06 and 08B07? 08B06 is the Venturi "T" install for the cooling system and 08B07 is a PCM reflash. The reflash is currently on hold as a software issue is giving some trucks a not start problem after the reflash. It is actually erasing the transmission computer info and has to be replaced to repair it.
Ford sends the letters out in waves so there isn't 2 million people calling at the same time. It can sometimes take up to 3 months for all the letters to be sent out. If you ever had a radiator replaced you may not get the recall because the dealer was supposed to install the "T" when it was replaced.
