AOD & No OD
This car was a freebie and has plenty of life left but has 1 issue, When shifting into Overdrive it does not catch at all. All of the other gears have a solid engagement. One of the companies that specializes in this tranny indicated it was either wore out which I'm inclined not to believe due to the fairly low miles on it. The other cause as they stated would be the servo that controls the shift is not functioning.
IF it is the servo can anything be done to massage it, test it, or otherwise get it to work again. I have not changed the fluid or done anything so far. Would a Professional Flush help or do I have to just pull it and spend a grand I don't have to fix it?
Any info, diagnostics or tips and tricks would be great!!
Happy Thanksgiving
Mark J.
) that loosens up the gunk, but I would hesitate to use any of the stuff. I dont think you will hurt a thing by driving it, I bet it will, one day, just start working. If nothing works, worst case is that you have no OD. Thats still cheaper than a repair---that $$$$ will buy a lot of gas. Another worst case is that it will never work and will one day just quit altogether. Then, you are about where you are now, needing a tranny rebuild, except that you may get many miles of good driving and use out of it first. Sounds like it may be a really nice car and a good find. LOL
I got the impression the servo or at least part of it is accessible through the pan and valve body, I was hoping I would be able to get a little more info on the servo, maybe find out if there is a moving part or which holes the flow comes through or even better if you can physicaly move it back & forth. Also since I will at least change the fluid & filter, is there a better fluid than the stock recommendation?
Thanks for your response it is appreciated!!
Al local parts house should have the ATG manual or maybe a parts supplier (yellow pages). I got mine several years ago from a "DACCO DETROIT" company locally. The manuals arent expensive, just a paperback. I will look for mine-----. It isnt really too difficult to change oil and filter yourself, just a little messy.
. Seems my memory is like a steel sieve. Yes, there is an OD servo. They are rated by letter A,B,C. A is the largest diameter and applies the most force on the band ie
erformance use. Most cars had the B servo----. I know for sure the SuperCoupes (superchgd 3.8 ltr T-bird) had the A servo. Not exactly sure what else had them, so I wont guess. The aftermarket makes even larger ones with other I.D's (such as A++). Depending entirely on your planned use, choose one. More than likely the one in the tranny is just stuck because of sitting, hopefully an oil feed port isnt varnished over. They are actually simple to get out and clean. Even in a stock motor, if you replace the servo I would go with an A because it will give a firmer OD shift.I suppose the band that the servo applies could be worn out or disintegrated, in which case it could be scoring the drum----not good! Look for metalic material in the pan---probably in the goo in the bottom. If the servo seems to be free, then thats more than likely the case.
Google "ATSG Manuals" and one of your hits will lead you to a parts supplier and a pic of the servo. You may even find an on-line proceedure manual. I will look for my manual, but I think you can get to the servo with the pan off, without having to remove the valve body. Dont know if you are mechanically inclined and wish to do it yourself.
I'll post the results to let you know what I find.
Thank you so much for the info!!!
