Seat Belt Retractor Spring?
My 99' is doing the same thing.
I'm thinking mine is just worn out and needs to be replaced.
on
I just replaced my driver's side belt assy... about $95 at http://www.trademotion.com/partlocat...?siteid=214072 .
Don't think there is any adjustment.. Ford really doesn't want anyone messing with it..safety item .
I just replaced my driver's side belt assy... about $95 at www.fordparts-fordparts-fordparts.com .
on
Yes.. it fixed the slow retract problem..The main reason i replace mine was cuz my darn dog chew thru the belt..!! (if you replace them, you need to remove the lower door frame panel to expose the torx bolt)
Rick_Fury
04-14-2011 08:00 AM
