guys im not sure if this is supposed to happen... My 95' when i get on the gas my transfercase lever moves with the motor... Im not sure if this is normal or should it be staying put... Also is it a possible tranny mount?
Yes check your engine mounts they are probably shot or some of the bolts are broken/missing. The engine/tranny/xfer case are all bolted together so they will all move together, but if the mounts are good it hardly moves at all.
yeah mine moves too and i have poly motor mounts (with a limiting strap) and a new trans mount. not a lot but maybe an inch total, but i also have a 3500 stall and other crap...
