Fuel Filter
Old Nov 20, 2008 | 02:32 PM
lmfire6229's Avatar
lmfire6229
Cool Fuel Filter
Has anyone had the fuel filter cover twist and break? If so....How the hell am I going to get it off so that I can finish my filter change?
Old Nov 20, 2008 | 02:55 PM
UGA33's Avatar
UGA33
Did you break by applying to much force to get it off? Gotta go down to the dealer and get a new cap. Is it the one on the frame rail or on top of the motor? The one on the frame rail's cap cost about $70
Old Nov 20, 2008 | 03:39 PM
ingman's Avatar
ingman
There are three different methods (1/2 drive, hex nut, and filter strap whench) to get it off whitch one broke?
Old Nov 20, 2008 | 03:58 PM
lmfire6229's Avatar
lmfire6229
It is the one on top....I was using the 1/2 in drive to take it off and it just cracked and crumbled apart. It is still whole and no fuel leaking, but I can not get it off......I guess I will have to get a filter strap or wrench to get it off.
Old Nov 20, 2008 | 05:33 PM
tazo's Avatar
tazo
FUEL/WATER SEPARATOR DRAIN PROCEDURE
Use a 15/16ths socket to get it off. Don't over torque these caps. The o-ring seals the cap.
Old Nov 20, 2008 | 06:13 PM
fordf150guy's Avatar
fordf150guy
sounds like he broke the one on the engine not the frame rail. might be able to back it off with channel locks.
Old Nov 21, 2008 | 07:24 AM
69cj's Avatar
69cj
Use a socket so as not to force it apart when twisting. Lessons learned; do not use the extension drive to open or torque. Use a socket.
Old Nov 21, 2008 | 10:08 AM
tazo's Avatar
tazo
15/16ths for engine mounted fuel filter. 36m for frame mounted fuel filter.
