Gas Pedal goes dead
Gas Pedal goes dead
Anyone with an idea about this? Every once and awhile (maybe once a week or two) my gas pedal goes dead or has no affect anymore. Most of the time it just idles fine but will not increase in RPM with the push of the pedal. Every 5<SUP>th</SUP> time (guess) it will run rough and die. Every time I let it sit for 2 or 3 minuets and she cranks up and goes.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Just for some history, I have changed both fuel filters ( long shot) I had the EGR replaced about 2 months ago ( sticking open and would not run), ran a speedo cable down the Exhaust pressure sensor. I unplugged the EGR after it was replaced and now have plugged it back in (thinking just maybe had something to do with it.... it did not.)
<o></o>
It does not give me a light and there are no codes with my scanner.
<o></o>
I have an
<o></o>
05 scurge with a 6.0
AirRaid
Cat seems to be missing………..
Edge Juice with Attitude
<o></o>
<o></o>
I have an
<o></o>
AirRaid
Pedal seems to be plugged in pretty well. Would the Cam Sensor not throw a code? Also, My wife is stating that it Surges during the times that we are having problems. I have not noticed that but she is pretty good with these things. Says that she will be stopped at a light and it will want to take off for 1 or 2 seconds and then go back to normal. I am going to be in trouble if it has two problems.
pete, any more info on this issue? Anybody else have this problem?
My 07 F250 is doing the same thing. Initially it had intermittent starting issues and if it would start it would barely idle and had a dead gas pedal. It now is happening while driving that the gas pedal will go dead and will be driving down the street barely idling.
It's been at the dealer 3 times with no fix as of yet.
This problem is intermittent and appears to be tough to troubleshoot. No codes and no warning lights.
Anybody have a clue what might be happening?
My 04 did the same thing. If I held it to the floor while it was in this mode and the turbo viens would slam open, dump a lot of smoke and then work again for awhile. Finally ended up changing the turbo, that was before they cleaned them as they do now. So if you try this and you get the black and I mean BLACK smoke and a over boost situation you are probably experiencing the same thing I did. Might just need a turbo cleaning.
the ICP harness was replaced and no future issue on mine
mine threw a code when the peddle died
p0299 turbo underboost related? not sure
when the icp harness finally failed i pulled a p2289
Grady...My 07 did it once .Dead gas peddle.Had to idle across a big intersection.I shut the truck off .Checked everything I could think of.Truck wouldnt start.Disconnected battery to see if that would help.Truck still wouldnt start .Called to have it towed . Dealership said there was no codes thrown except history of me disconnecting batteries.They told me truck was fine. Sent me on my way. Two weeks go by .Start truck up in my driveway .Starts up fine. Go to backup ,and its running really rough.Reved the motor a lil to see if it would help.No power .Would only idle back into driveway.Didnt touch batteries this time.Looked everything over again ,and everything looked good.Started next day .Ran fine .Then went to dealer to drop off.They still couldnt find anything wrong with it....lol.Just said they gave it the updated flash
Sorry about the brief response . Trying not to make it to long winded.
So far truck has bein running fine. Except for fuel gauge sticking on "E" after fill up a couple times,but thats a different story.
It has been awhile ago on this but I "THINK" the issue ended up being my ICP. (someone suggested that) Anyway, it did it again, dead peddle, I hopped out, and unplugged the ICP (mine is in the valve cover) looked at the connector, blew in it (seemed like the thing to do I guess) and plugged it back in. (the Scurg was running this whole time). It immediately started running great and it has never done it again. I do not know if unplugging it reset something, or if it was not making good contact or what, I know better than to unplug things while it is running, but at the time I was VERY sick of the thing and did it out of frustration.
Anyway, that was over a year ago now and I have not had the issue ever again.
My guess, ICP values were not what was expected and it locked the whole thing up.
