Alaska Chapter Join Chapter, Leader:
Driving the ALCAN in Feb with a diesel.
Old 01-08-2009, 09:39 PM
Mwachel's Avatar
Mwachel
Mwachel is offline
Hello everyone. Quite a few questions for ya. I lived in Anchorage from 1997 to 2001 and loved it. I now have a job opportunity and will be coming back to Anchorage in Feb.
Any advice for driving the Alcan in Feb with my 2005 4x4 F250 6.0 towing a trailer with a couple of four-wheelers? Anyone else done this with a trailer? I have driven it in the spring but not the winter.
Plans for the truck before I leave:
DIY stuff:
-fuel filters
-full syn oil change
-install cord for block heater
-order and install winter front from Alaska Tent and Tarp
-check anti-freeze to make sure it's good to -60
-anti freeze windshield wiper fluid
-buy set of chains
-anti-gel for the fuel
-10 gal of extra diesel
Dealer:
-tranny flush
-check brakes and general look over
I plan on having survival gear, propane, stove, sleeping bag, blankets, etc. Also I might buy the SPOT http://findmespot.com.
Thanks for any feedback or advice!
Mike
Old 01-08-2009, 09:53 PM
bigunred's Avatar
bigunred
bigunred is offline
Sounds like your planning well dont for get the extra water and food should you need it. And good luck.
Old 01-08-2009, 10:42 PM
Ak68F250's Avatar
Ak68F250
Ak68F250 is offline
Might want to add a cb to the list.
Chains for the trailer if you bring one.
Good luck.
Old 01-09-2009, 12:03 AM
Mwachel's Avatar
Mwachel
Mwachel is offline
Good luck.
Chains for the trailer...good idea. I will check on the prices.
I have a HAM radio but not a CB so that is also a good idea. Thanks!
Old 01-09-2009, 12:16 AM
bigunred's Avatar
bigunred
bigunred is offline
Ive drove it twice in feb and once in jan. It was surprisingly uneventfull all three times. I have had worse luck in march and april. Good luck and safe travels
Old 01-09-2009, 01:35 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
should be a cake walk just take your time and enjoy the drive. dont over do it.
Old 01-09-2009, 10:36 AM
Tom92F150's Avatar
Tom92F150
Tom92F150 is offline
Not really trying to hijack the thread, but I'm doing the same trip in two weeks in my '92 F150. I'll make the same preps as Mike for the most part, but should I look into a winter front/grill cover for my 4.9L? Could I get away with sliding a piece of cardboard in front of the radiator?
Old 01-09-2009, 11:12 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
cardboard is much better!! just cut a diamond out of the center and fold it back and put directly onfront of radiator core.
Ray
Old 01-09-2009, 11:14 AM
Mwachel's Avatar
Mwachel
Mwachel is offline
From the research that I have done cardboard could work in a pinch. Covering up the grill does more than just keep the engine warmer. It also keeps the cold air from hitting all of the other stuff in there like the power steering pump, master cylinder, etc. When the temps can be -20 or lower any little thing could make a difference.
With my diesel I want to TRY and make sure the operating temps stay above 180 degrees (I have a digital gauge). Normal for my truck here in Las Vegas is 184 to 210. I also want to keep as much heat in the engine area for as long as possible after shutting it off.
Old 01-09-2009, 11:21 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
get thick cardboard from a appliance box!
Old 01-24-2009, 02:00 AM
Mwachel's Avatar
Mwachel
Mwachel is offline
I may be using the cardboard trick. I have the job and will be driving up before the end of Feb! WOO HOO!
Old 01-24-2009, 03:52 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
i got some cardboard so when you get here let me know.
Old 01-24-2009, 10:08 AM
Mwachel's Avatar
Mwachel
Mwachel is offline
Thanks, b-uno. I am going to have to find some before I leave. I want to have it in the Yukon as I am coming up.
Old 01-24-2009, 01:49 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
you can always strap pine tree branches to the raditor in emergency, they smell good too.
Old 01-24-2009, 01:58 PM
Mwachel's Avatar
Mwachel
Mwachel is offline
Hey, I don't need no scented pine tree hanging from my mirrors! I have the real thing strapped to the grill! WOO HOO!
Quick Reply: Driving the ALCAN in Feb with a diesel.
