Just bought a 1993 F-350 7.5l with service bed Clutch is on the floor I hear this is common problem Is it clutch master or slave or should I just replace both .
I would fill the clutch master cylinder with brake fluid and pump the clutch pedal several times and see what happens. Yes, I realize you'll have to pull the pedal up also. The clutch master cylinder is just inboard from the brake master cylinder along the firewall. Don't forget to remove that rubber cup from the master cylinder after you screw the cap off and before you add brake fluid.
Do you mean "it goes to the floor" or "it stays on the floor"?
Why start with the most expensive parts first?
Have you already checked the crossover shaft bushings, pushrod retainer clip and firewall as Lazy K suggested?
Goes to floor and stays there .Everything looks good bushings have min wear and everything is hooked up and mounted secure even put fluid in it and pumped several times stays on floor
