99 f350 psd quit
99 f350 psd quit
can anyone help i have a 99 f350 6speed diesel i was driving two days ago the service engine light come on and the truck shut off so i towed it home check all the norm like the fuel bowl was full filter was just done and still clean oil is good i can hear the fuel pump running i put a new cps from the ford dealer in it and the truck started up for about 20 sec and shut off if sits for a while it will start the same and shut down again i have another 99 f350 so i swaped the computers and still nothing but the other one runs either way i also checked all fuses and there good so im stuck any help!!!!
on
Just a thought. Try unplugging the ICP sensor. PCM will go into a default setting. See if it will keep running then. You need to read the codes to see if it steers you in the right direction as to what the problem might be. Like Glenn said. New CPS, especially if the gray one, could be defective.
i just put the cps from the running truck on the not running truck did the same start for about 20sec and shut off so i checked all the cps in the the running truck they all work so thats not it when the non running truck start's for thoes 20sec if you try to hit the gas it don't rev up at all it just idle then shut off and after it's start's it won't start again for a couple of hours and seem's to start if you unhook the battery's anything i'm missing
Here is another thread about truck just dieing, maybe it will point you in the right direction
https://www.ford-trucks.com/forums/7...-psd-quit.html
