Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
How do i safely clean my 7.3l engine compartment
Old 11-12-2008, 05:12 PM
Fordfreak1978
Fordfreak1978 is offline
Fordfreak1978 is starting off with a positive reputation.
Talking How do i safely clean my 7.3l engine compartment
Hey,
just had my oil line go out on my 7.3 while on the freeway. I fixed the oil line, but it shot oil all over everything, what is the best way to get the oil of of the engine. I was just gonna boil a pot of water and carefully pour it in the valley? questions comments concerns????
Old 11-12-2008, 05:16 PM
F250_'s Avatar
F250_
F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
1. Cover air intake filter, relays, oil filler cap, and top engine sensors with zip-lock baggies.
2. Soak down with Simple Green Degreaser.
3. Let the SGD work for about 10 minutes, but do not let it dry in place... might need to spritz it a few times.
4. Rinse with low pressure water from a garden hose... might need to use a little nozzle pressure in a few hard to get to spots.
5. Repeat if necessary.
6. Remove the baggies.
7. Start up the engine and let it run for a few minutes to help the drying process.
8. Spray on some Teflon Tire Shine from Dupont to really, REALLY spruce up the engine bay.
Check out my gallery... I did the same process with GREAT results.
https://www.ford-trucks.com/user_gal...&albumid=29422
Old 11-12-2008, 05:33 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
Don't forget to cover the power steering pump resy. It has a vent hole that water will get in. Honestly, I never worry so much about the sensors and relays. I do try to limit the water on the big wire harness plugs on the drivers side.
Old 11-12-2008, 05:36 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
Spray with your choice of degreaser and wash with a hose... Easy cheesey...
Old 11-12-2008, 05:44 PM
F250_'s Avatar
F250_
F250_ is offline
Yep, I completely forgot about the PS cover... thanks for bringing that up, Barry.
Old 11-12-2008, 05:55 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
when I bought my truck..I pulled every wire plug I could find and dabbed in electrical grease made for sensors and I replaced any bad rubber weather rings in the plugs...if I need to pull a plug ill add more grease if I need to..the grease keeps moisture out..cover up what has aleady been said above..on a cold motor cause steam is worse then water..steam gets in to places you never thought of..spray her down with simple green...brush down what needs to be brushed..then I use a power washer and spray her down....I do this twice a year just before she gets waxed..I have never had a problem..I have done this to every car / truck I ever owned..
Old 11-12-2008, 06:21 PM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Don't forget step #6! Don't laugh, a few on here have done it.
Old 11-12-2008, 06:51 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
That would've been me...
I only cover the alternator, PS lid (VERY IMPORTANT!! There's an open hole that will let water right into it!), and 6637. Then spray with Simple Green & hose off. **REMOVE BAGS**.
After you make sure to remove the bags, check again...
Then start the engine to dry it. I then spray some tire shine on the rubber/plastic parts. Looks like this when done:
In my defense, I received a lengthy technical phone call after I was done washing the truck, both on the outside, and the engine bay. That's how I screwed up. The only bag I left on was the 6637, and after starting it and thinking it was running funny because it was wet, I gunned it instantly realizing what the real reason was. The Wal-Mart bag over the filter crushed it like a beer can. Fortunately, it didn't crush it enough to tear it, so I drove it to the Napa & bought a new one. $50 mistake.
Old 11-12-2008, 06:56 PM
zx250's Avatar
zx250
zx250 is offline
Yeah, those bags are a bi**h to get unwound from the pulleys ain't they?
Old 11-12-2008, 07:42 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
danskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to beholddanskool is a splendid one to behold
Dang that Bay is clean !
Old 11-12-2008, 08:40 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Don't know -- that was Scott...
Old 11-13-2008, 07:25 AM
zx250's Avatar
zx250
zx250 is offline
Well, I may or may not have done that myself.
Old 11-13-2008, 07:39 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
LMAO!!! I see.......
Old 11-13-2008, 12:57 PM
pdx02's Avatar
pdx02
pdx02 is offline
pdx02 is starting off with a positive reputation.
That seems like it's so easy to do. Am I missing something?
Old 11-13-2008, 01:13 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
It's as easy as it seems. Don't forget what I have on my degaser bottle.
<CENTER itxtvisited="1"></CENTER>
Quick Reply: How do i safely clean my 7.3l engine compartment
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
