Stupid light...is something wrong or just a short?
Charging system light still comes on and off after Ive done the following...
-replaced harness plug (the one that has 2 wires going to alt)
-taped all wires going to and from alternator including the harness ontop of the VC
-checked voltage(while running) of both batteries, 14.34
-unplugged 2 wire harness and the light goes off, plug it back in and comes back on
What else is there to do? Am I missing a wire that might be chaffed or something? Im going on a 13 hour trip in a week or so and I really dont want to stare at that light coming on and off and not KNOWING if my alt is going to die on me halfway through it or not!
If there is a wire that causes it does anyone know the color of it?!
Im ticked off and tried everything I can think of!
You might as well be talking a different language! This alternator is less than 2 years old IIRC. Ive done everything except take it completely off and check anything. Ill be honest with you, Im not afraid to poke around with anything, except the alternator!
Age don't always mean much. It sounds like an alternator going bad, although it could be something else. Next time it's off, load the system, lights, fans, ect and see if you can make it come on. If I were leaving on a long trip, I would at the very least buy one to carry with me, If you don't use it, you can return it when you get back, if you need it, you can change it on the side of the road with mimimal tools.
What you are describing was my exact issue, went on for several months light would come on sometimes, sometimes not.....I asked the auto store guy cause he tested it several times on the truck including the day that I pulled it off and took it in and it tested bad. He said maybe cause their tester was really built to test with one battery, or that the machine does a more thorough job, either way my alt was bad after just over a year. Good luck I spent months pulling my hair out because of that freakin "nuisance" light
the voltage regulator is going bad. If it is a chain store alt witha lifetime replacement warranty, pull it off take it to the store and tell them its fried, the'yll check it on their inside machine and then youll get a new one.
Once it comes on and stays, you better be close to where you want to be. If like most, it will start to come on more ofter and for longer periods of time.
Well looks like I have a nice job to do tomorrow. Good thing Ive got the ol reliable Mustang to take me to the store. Anyone recommend a good place to get one from? The one in there now is from NAPA but It was put on at a shop(shops gone outta business) and Ive heard bad things about the Auto Zone alternators as far as lasting. I really dont wanna have to change the alt out every other couple of months.
Edit...I know about DB's but I need to get it tomorrow. No time to wait on delivery
Its not a plug, its a terminal covered with a cap. 8mm nut , and then the 12v wire is loose.(disconnect both batts before removing this wire.)
