Hemi Spankdown
11-10-2008, 07:35 PM
on
Hemi Spankdown
It runs when it wants to. HP stroker ignition cuts out .TFI/getting hot.
11-10-2008, 08:00 PM
on
11-10-2008, 08:51 PM
11-10-2008, 10:09 PM
what does your post mean?
11-11-2008, 08:41 AM
yeah huuh, what language is that
11-11-2008, 03:29 PM
Quote:
Originally Posted by
guitarnik
I'm almost certain that it's English. We are all just a bit confused on this one...
11-11-2008, 04:17 PM
on
Hello
11-11-2008, 06:15 PM
on
Whats up bro? I could use some advice. My`90 F-150 has developed some ignition problems. I modified the engine with just about everything. Now it will run for awhile until it warms up,then it will sudenly just die. I`m pretty sure the TFI module is gettin` too hot, but dont know what would be causing it.
11-11-2008, 06:19 PM
let me go get my crack pipe fired up.
ok, i m bak but nuthin es makin cents.
11-11-2008, 06:27 PM
on
What would caus the TFI modul to over heat
My truck will run real goood for about 15 min. ,then it cuts off. What the *&%# could it be?
11-11-2008, 06:36 PM
on
chek for codes.. or if your so shure. change it then!
11-11-2008, 06:43 PM
on
They are susceptible to heat soak.
11-12-2008, 02:33 AM
The TFI module has probably had it.
Is yours on the fender or distributor?
There probably isn't any grease on the back of it between it and the heat sink.
11-13-2008, 12:05 PM
on
pickup coils can have that effect also, when they get hot then die cool down and run like a top again.
11-14-2008, 11:49 AM
what have you done to it? i know that msd boxes will do this if they go underwater
