Needle Bearings Found in Oil
If your motor was compromised this whole time and Ford kept telling you "Oh that's normal, don't worry about that". It is their fault for misdiagnosing and not finding this the first time. Hopefully, they'll own up to it, fix it, and have you on your way.
Well the truck has been at the dealership for over five weeks. They had the truck back togehter the first two weeks and it should have been out the door. Now they cant get it running right. The first time they had it back together the tech didnt get the timing right and it would not even run makes me wonder it they bent the valves. The motor was compromised before they worked on it now with five weeks of some tech not knowing what he is doing it is really messed up. Ford has given me the 200,000 mile waranty on this truck with no deductible but I really just want a new motor. Something fishy is going on with this truck it feels like im not getting the whole story.
This will result in the lifter riding on the cam, grinding in.
It won't cause persay catastrophic damage, but a new cam, lifter set, rod/main bearings and low pressure oil pump would certainly be in order. Do you happen to have a bill of parts that were replaced? I can say for certain if I was working on the truck, that would be the minimum amount of parts replaced. It should not, however, destroy the entire assembly.
Luke MacIntosh
02-09-2016 01:59 AM
The Fool On Th Hill
21
02-25-2012 06:33 PM
MRStace84
09-21-2010 09:20 PM
