- The EVP sensor is probably shot. Plugging the green hose will also reduce your mileage.
I only pluged the green hose for a moment to see if there was ANY vacuum going to the EGR. There was none, even when the motor was revved a little. Then I put the hose back on the EGR. Now, the sensor is the device that the EGR sits atop of correct?
Yes, and you'll need to go to the dealer for the correct part. The ones from the discount stores are junk. There is a pin in them that moves with the EGR, and a lot of the aftermarket sensor's pin is the wrong length causing an error code.
Thanks for your help. Ill remove the EGR and clean it whenever i get the time to replace the sensor.
My bronco has gotten 10 mpg with the EGR working and without the EGR working, so on it I am not convinced that the EGR was worth while for that truck but I got 13 mpg driving 55 mph which is only 2 mpg less than when it had the E4OD. The EGR is controlled by a switch that is cycling to let vacuum onto the valve and off so that the vacuum motor holds the EGR valve at the right position. Its vacuum is suppled by the vaccuum resiovoir canister on the pas. fender, which also supplies vacuum to the A.I.R. switches for the exhaust. The best mileage you can possiblity hope for is ~20 mpg if you are lucky with these trucks. Weight, gearing, and tire size are about the only factors you can truelly work on to improve the mileage on these trucks. Low weight, changed gearing to b/w 2.75 and 3.10, and 28 in diameter tires or buy a sedan because you just made one out of your truck.
Never heard of an older F250 getting 14+ mpg with a 351 and a C6 tranny. The best mileage on these trucks that i have heard about is 13mpg. And if you ever drop your gear ratio down to a 2.75, or even a 3.10, you have just lost a ton of towing power, and if you use your truck for any towing or pulling power like i do, then this is deff not the way you wanna go. Obviously you would get better gas mileage with a car or smaller motor. but for some of us, we like our trucks. im just trying to figure out what the he!! is going on with this truck.
