99 Super Duty show air bag 24 code..HELP!!
Old 11-09-2008, 02:10 PM
AMXAL
AMXAL is offline
AMXAL is starting off with a positive reputation.
I have a 1999 F-250 Super Duty that I have owned since new, the last 2 months it has been stored outside, I live in the Chicago area, and has been exposed to all the elements. I went to use it yesterday and the air bag light is showing a 24 code, I think it did this before after being outside but went out after using it for awhile, I'm thinking I have a connection that is corroded due to moisture, any ideas where to start looking, can anything bad result from this, I'm planning a trip and need to determine if it needs to go to the dealer, or is it something I can fix. any help is appreciated. AMXAL
Old 11-10-2008, 01:30 AM
2000psd
2000psd is offline
2000psd is starting off with a positive reputation.
Old 11-10-2008, 06:04 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
LFC (lamp fault code) 24 ECS Module is Faulted
B1 CHECK FOR A HARD OR INTERMITTENT DTC Retrieve and record any continuous DTCs for use later in this pinpoint test.
* Was DTC B1342 retrieved during the on-demand self test?
Yes
This is a hard fault. The fault condition is still present. This fault cannot be cleared until it is corrected and the DTC is no longer retrieved during the on-demand self test. INSTALL and CONFIGURE a new ECS module. GO to B2 .
No
This is an intermittent fault. The fault condition is not present at this time. INSTALL and CONFIGURE a new ECS module. GO to B2 .
B2 CHECK FOR ADDITIONAL DTCs
Refer to the continuous DTCs recorded during Step B1.
* Were any continuous DTCs retrieved during Step B1 ?
Yes
Do not clear any DTCs until all DTCs have been resolved. GO to the Air Bag Electronic Crash Sensor (ECS) Module Diagnostic Trouble Code (DTC) Priority Table in this section for pinpoint test direction.
No
CLEAR all DTCs.
Sounds like you need to get the truck on a scanner to see if there are any other issues. Maybe if you post your location, you'll get lucky and a fellow member that lives close by will have a scanner he'll put on your truck for you.
nbettes
Fifth Wheel & Gooseneck RV Towing
15
12-04-2016 10:14 AM
CLE-PRE
06-22-2016 06:28 AM
wickdgt
1999 to 2016 Super Duty
19
03-07-2015 08:46 AM
h2omotorsports
11-14-2008 04:44 PM
vidrine2
06-23-2007 05:49 AM
Quick Reply: 99 Super Duty show air bag 24 code..HELP!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
