Poor MPG and Snow Plow Install Questions
Hello All,
<o></o>
I have an 00 F250, 7.3 PSD, SC, LB, 4X4, 166K, DP Tuner, 4” Magna Flow, gauges, 6637, 265/75/16s.
<o></o>
Shortly after buying the truck, I had all fluids and filters changed and the driver’s side exhaust manifold replaced due to a exhaust/boost leak. I also cleaned the EBP tube the best I could as I could not get it off of the truck. I was able to thread weed trimmer line all the way through it.
<o></o>
The mechanic who worked on it thought it ran a little weak and thought I might have a minor injector issue but he told me to add the DP Tuner to it and be happy.
<o></o>
Well, my only complaint is the fuel mileage. I get around 14 running empty not really pushing the truck hard. It doesn’t matter if it is city or highway, I get around 14mpg with or with DK white or 2 cycle oil. Not much smoke that I have noticed. At WOT I build around 25lbs of boost.
<o></o>
What else can reduce the fuel mileage that I should have checked? Short of the dealer, is their someone in the Washington, DC Metro area I can take it to who can scan the computer for codes, check the injectors, etc? How much should I expect to pay for these tests?
<o></o>
Also, my CPS was changed by a Ford Dealer back in 05. I don’t know what color it is but have noticed that the truck runs a little rough while using the high idle program on my DP Tuner. Can a crappy CPS limit mpg? I do have a brand new Ford gray spare that I could swap out…
<o></o>
Any recommendations on anyone to install a Meyer Snow Plow on it for me?
<o></o>
By the way, I am a little confused about 2 cycle oil as a additive. Is it good to use or not?
Thanks…
<o></o>
Neil
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
Thanks…
<o></o>
Neil
Check your up pipes for leaks. Make sure that all the IC clamps are tight and that there are no more boost leaks. Fuel mileage depends on how you drive it too. (I know that one is way obvious)
There are a few members in MD that have AE scanners maybe you can hook up with one of them.
If you are seeing dusting and want to check the tension on the boot clamps, I think that the torque is supposed to be at 71 in-lbs.
He said he gets 25 lbs of boost so one would think his up-pipes and IC boots are good. Do to the limited info I can't offer an educated guess as to why his mileage sucks but he never said what program he is running in his DP, maybe he is running something like a 120hp program.
I just downloaded the mileage program into my Flaspak and no difference in power but the mileage is up at least 2mpg, general running around (not freeway) it is about 16.5 actual, not a lie-o-meter.
Good luck on figureing it out, try to find out what program is in the DP.
Dave
Dave
Mpg
I am running the truck using the 80E tune on the DP tuner. I do need to consult Jody why the trans seems ti hit 2nd gear then imediately shift to 3rd on downshifts. Again, I drive it pretty gentley. Maybe I should try the 60tow? Then again, I got the same MPG running stock before the DP Tuner.
Going to run BFG A/T 285/75/16 Load Range D tires for the winter. Hopefully that won't reduce my MPG but will help it on the highway going over 70mph....
I'll look again for boost leaks. Does anyone have a picture of key areas to look at?
Thanks...
Neil
Thanks...
Neil
Hello All,
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
Thanks…
<O></O>
Neil
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
<O></O>
Thanks…
<O></O>
Neil
Thanks...
Neil
Thanks...
Neil
Things
I live in Bowie, MD. From my understanding, installing a mounting carton on a 2000 F250 requires drilling the frame. I probably don't have the drill required but might be able to borrow one. I certainly don't have the bits or another pair of hands to help me so I'd rather pay to have it done right. I just received the hardware (expensive) to mount everything.
l suppose taking the tube off help me clean the tube better but I was able to get the weed trimmer line from one end to the other and brakekleen too. If I was to have the computer scanned, would a clogged BPV tube or bad sensor show up?
Thanks..
Neil
Thanks..
Neil
