fifthwheel goose neck combo hitch
Fifth wheel hitch with underbed rails - removal and install is done in truck bed at hitch, not under truck.
All Signature Series Fifth Wheel Hitches | Drawtite | Reese | Hidden Hitch | Blue Ox | Rola
Gooseneck plate that fits on same underbed rails as above hitch
Reese Signature Series Gooseneck Hitch 30845
I have the fifth wheel hitch above and it is an excellent unit - single jaw wraps around the kingpin - no slop in hitch when towing, as well as 4 way pivot. Don't have the gooseneck plate as I don't have gooseneck trailer at this time, however was looking at "future expansion" so chose this setup.
If your wanting to pull a 5th wheel on your flip down ball they make gooseneck adapters so you can pull a 5th wheel on a ball, generally around $500 new.
I prefer the B&W setup with a companion, but the companion itself retails for about $800, not including the turnover ball itself. The only reason we use it is because we're hooking up to different trailers all the time.
And fyi the B&W is a 4 inch hole
Unk Jim
11-21-2014 01:43 PM
