Master cylinder location
I say under the floor since it gives the firewall a cleaner uncluttered look as opposed to an ugly brake master cylinder and booster hanging out their for everybody to see. I don't believe there is anything you can do to dress up an ugly looking setup like that however this is just my personal opinion, it's your truck and you can build it anyway you like. Everything I build always has the setup under the floor. Something else to take into consideration is that if you hang the pedals/master cylinder on the firewall it will put undo stress on the firewall that was never designed to have this setup hanging on it. If you notice vehicles with firewall mounted pedals the area around the unit has additional bracing and material placed to deal with the pressure and stress put on it. I know this setup has been done successfully on all kinds of early cars and trucks but it is just something to consider when making that decision. For me there are three things that I won't compromise on and that's brakes, steering, and suspension as I believe safety is paramount.
If you buy the firewall mounted booster and bracket from CCP for the 53 thru 56 ( it will not fit a 56, bracket is to short by about 3/8 of a inch ) you may be suprised at how far left you have to mount the booster and m/c.
My truck was already finished when I started having brake problems, so I bought their kit thats how I know it will not fit a 56 and my fuse panel was where they wanted the booster.
I made my own bracket and pedal but used their other components, brakes work great now.
Do have a new ccp brake booster mounting bracket and pedal assy I would like to sell.
Chuck
Chuck
on
Put it on the firewall where it will work the best. I used some flatbar and angle iron on the inside to prevent firewall flex. Those under the floor master cylinders are hard to fill, sometimes get in the way of exhaust, and the fluid drains back causing excess pedal movement. There must be a reason Detriot doesn't put them under there anymore...
Hey Pappy, Check out "Industrial chassis" on the web, though the picture leaves a bit to the imagination, they are plenty strong and the weak firewall issue goes away as this component triangulates the dash and the firewall. I installed one on my 55, it fit like a glove and even had space left over to mount the steering column...LoL! It's actually designed for the steering drop ....
Since I tore out the original tranny crossmember on my 49 I didn't have a spot under the cab to put the MC back on. I fabbed my own hanging pedal assy and hung a MC and power booster on the firewall. I have disc prakes on the front of my 49.
When I fabbed my pedal assy I tied it into the firewall, dashboard, and steering column just like in modern cars.
I used the basic pedal, pivot, and spring from a mid 90's Ford focus (don't ask...it was a freebie) I fabbed the mount with flat bar and angle iron. I had to extend the pedal a bit. My pedal comes down on the right side of the steering column.
Good luck
Bobby
Good luck
Bobby
on
I don't know anything about the kits. I made my own supports like Bobby. Take an original hanging pedal and support out of just about any vehicle and fabricate braces to make it bolt to the firewall at one end and the dash at the other. It will be plenty strong enough. My pedal is on the left side of the column and hangs below it but I use my left foot on the pedal anyway so I wanted it there. If you use a wide pedal it won't matter which side of the column it is on because you would be able to brake with either foot. Sorry, I took a lot of pictures when I was building my truck but none of the steering column support. I used the pedal assembly out of my 87 Chrysler front suspension donor but you can make just about any salvage yard pedal assembly work so unless the kit is cheap I'd spend the money elsewhere...
My power brake booster and dual reservoir master cylinder are under the cab. I do not like the looks of it sticking out there under the hood...when it was not put there originally.
I also have a vacuum reservoir under there to help with vacuum, since I am running vacuum wipers as well.
The kits fit well and work great.
Oh..as far as adding fluid, if you do everything right, you only need to check it once or twice a year. Just check the level (a hand mirror works great for this) when you have it in the air to grease everything. I have an oil squit can filled with brake fluid (in the box in the back) that I would use to fill it, if it ever needed it.
Mine has been under there for around a year and a half. Mine is almost a daily driver (I rarely drive my other vehicle). I have never had to add fluid to it.
EDIT: Here is a pic of under my hood as well (dirt and all):
My 51 f1 is going to be in da’ floor.
