93 E350 Motorhome Van - In-tank Fuel Pump
I need some help in diagnosing a concern.
My E350 is running and driving fine. But, I kept hearing this whining noise coming from the back and ultimately crawled under to discover that the noise is coming from the in-tank fuel pump. I wouldn't be that concerned about the noise, but, the pump runs continuously as near as I can tell.
I doubt this noise is normal. Never heard that from any of my other in-tank fuel pumps. I'm thinking I better drop the tank and replace the pump before it fails and leaves me stranded!
Do you guys agree?
Thanks for the replies in advance.
Tom
Do you guys agree?
Tom
05chop
Thanks for the reply. I added to the original post. "I wouldn't be that concerned about the noise, but, the pump runs continuously as near as I can tell."
I should have included that from the start. That seems to indicate that the pump is working overtime to keep up maybe. This is happening with the engine just idling and I assume while driving too, but I can't hear that for the road noise.
I don't have a manual for the van like I have for my F250, but I will get one. Thanks.
Your engine is EFI it need the pump to run all the time to supply fuel. If you turn the key to ON but don't start the pump should run and shut off after a few seconds. It's normal for them to get noisy over time. Change the fuel filter if it's clogging up it'll make the pump work harder and whine a little louder.
The in tank high pressure pumps are known to make noise if the filter is restricted. So change the fuel filter and if its still noisy, then its likely on the way out.
Its easier to change it an a preventative measure than on the road and having to pay a hefty tow bill and an out of town shop to do the work.
xavier9480
07-27-2017 07:42 PM
DrZoom
06-29-2017 07:03 AM
E30tdf
09-09-2010 08:39 AM
