Lets see lowered attitude 2wds dents here
#962
There is really no story behind the patina, I was just trying to accomplish the paint in my head. I was just imagining a vehicle that has never been washed, been through some barns, Been hog hunting. That sorta thing lol. So I sat down and drew me a photo up. Then had my dads shop order me some ppg chromabase whites, browns, and blacks. Then bam, Just went to town on it lol.
#963
Have to bring this thread back around.
Been dealing with some charging problems, So I replaced the alt, Still acted the same, Then messed with the voltage regulator and everything is working great. I got my projectors and hids wired up, Still have to aim them up alittle. But they will do for now. Also added clear to the truck to give it a deeper look.
#965
#966
I am using Dodge 16x7 steelies (in the first photo im running 97-03 black hubcaps).Now i'm running some hubcaps I found at the shop, ( no markings on them ) And tire size i'm running 225/75/16 I believe. Im still in the market on finding the 17x7 version.
Stock 97-03 hubcaps
Some random hubcaps I found at the shop. Looks to be a old Mercury or Lincoln logo on them.
Stock 97-03 hubcaps
#970
If you dont run spacers, you might run into hub mounting problems on the front. I just had mine milled to fit the hub, But then rubbed on the coil tower. So then ended up just having to run a 1" spacer.
#972
So at the expense of displaying my ignorance and rookie status, I'm posting a video of my truck project. 74 body onto a 78 chassis. Doing some lowering while I'm into the swap. I may need to shim the rearend for proper drive shaft angle, but that should be easy enough.
Nothing done yet on the front end, but I plan to do a coil cut and I-beam bend. Just can't afford drop beams at the moment. I know they'd probably be the preferred way to lower, but by doing what I'm doing, I should have about $50 in lowering shackles, which may ultimately come off as well. No drop blocks. Took them back as I won't need them.
I'll keep videos posted with progress. I'd appreciate the feedback as well.
William
#975
