Lets see lowered attitude 2wds dents here
#151
You can see I painted my inserts and bumper black too. Muttly is awesome too, I'd love to have a 4X4 crew like that!
Ok, now back to the topic Lowered trucks. I found this one while I was looking for the pic of the red one. It says in his description it's body dropped 6 inches.
#153
I like the green and the red ones. not so much the burnt orange one.
back when our trucks were new Ford and Chevy had different grills and paint schemes for vehicles. nowadays when the new body style comes out so does a new grill; they always use the same grill throughout the years. i.e. the dentsides had 3 different grill styles in the 7 years they were built. and it also seems like there are only a couple of different colors for the new truck.....black, silver, red, white, and that's about it.
I have a black grill on my truck now. several weeks ago I found a gray argent grill in a junkyard in rather good shape (1 crack). so now one day when I go back and get the grill shell, too, I'll swap over to a silver insert.
#155
#158
On my 74 I installed the Fatman MII setup, and rear 4 bar all with coilover shocks right now. It sits about like the green one pictured above. Unfortunately, I dont have any pics of it right now because the wife deleted them off the camera and its in pieces right now while I work on the body. As near as I can figure, I dropped the front about 6 inches and the back about 8. I put 1 degree of rake on it when I mocked it up. I like the way it sits. The plan is to swap out the coil overs with airbags some day so I can drop it another 4 inches when I pull up to the curve.
#159
The green truck is NOT Body dropped. If it were , it would have the rocker panels and front bumper sitting right on the ground. Our dent side frames dont hang down really far right, what, 6" or so under the cab? As stated above, a traditional body drop consists of cutting out the cab and bed floors, sinking the cab and bed down OVER the floors, sectioning out enough sheet metal to sit the rockers down flat, then rewelding it all back together. Some people even go as far as going to the doors, and just cut off the rockers. I'm in the middle of doing a traditional body drop to my '88 ext cab S-10. I AM keeping the rocker panels though. Yes I know, not a Ford... what ever, its my first truck, I love it, and I'll never part with it, no matter what emblem it wears. So anyway, A channel job refers to basically just cutting "channels" in your floors to fit the frame rails up into, vs cutting the whole floor out. Usually this also requires fabbing up a trans and driveshaft tunnel too. This is how alot of old school hot rodders did it back in the day. A "stock floor body drop" is when you build either a full tube chassis, or just tube it from the firewall back, and Z the stock frame for up front, in order to lay it out flat. Most of the time floor modifications are not nesesary then, hence STOCK floor body drop.
#161
In theory yeah, but I don't know why anyone would go through all the trouble. You can bag a suspension for around 1,500 - 2,000 bucks, if you have a few resources and do it yourself, or spend a rediculus amount of time and money bodydropping it. Alot of people dont think of all the stuff you need to tweek, like fenderwells, firewalls and heater boxes, door jambs, sterring column locations, fuel tanks and filler necks, shorter pedals with shorter throws, relocated brake boosters and the list goes on. I can't say based on those photos either way, but it looks to me like all the ones I've seen that are bagged and laying frame, without a body drop. But you're right, anything is possible. I'm wondering if the green one is running a Mustang II front suspention cuz on beams you ussually have alot more camber up front aired out. Then again, if its not bagged, just lowered... Looks good either way though, thats whats important right?
#162
#163
look at this site http://www.streetsource.com/ViewOwne...rofileID=43273
#164
bmarkline
can I ask you what kind of coil overs you are running up front?
#165
Me? I bagged a Chevy, alot easyer than a Ford, but when doin an air bag suspension you do not use coil overs, just air bags (I used double conveluted, single ported, 2600lb ones) and shocks. Well you don't really need shocks, but for safety's sake put them on. Air ride technologies has the "Shock wave" which is nice because they have the shock built into the air bag, but they are a little pricey and only get like 5" of travel from what I'm told. Those WILL bolt in place of a coilover- alot of hot rodders use them.
