Should my F-250 have keyless entry? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-03-2008, 11:50 AM
edd9000
edd9000 is offline
edd9000 is starting off with a positive reputation.
Hi first post. Just picked up a 2005 F-250 XLT, but it didnt come with any remotes and the key isnt chipped.
Should the xlt have keyless entry as standard? or should the key be chipped?
The truck has evidence and alarm was once installed, im wondering if this is causeing problems.
Thanks for your help.
edd
Old 11-03-2008, 12:07 PM
riggz's Avatar
riggz
riggz is offline
riggz has a good reputation on FTE.riggz has a good reputation on FTE.riggz has a good reputation on FTE.
What problems are you experiencing?
Old 11-03-2008, 12:09 PM
edd9000
edd9000 is offline
Well i tried to turn the ignition on and off 8 times to see if it would cycle the locks, as per the programing instructions, but it didnt.
Other than that no problems othe than having to use the key in the door.
edd
Old 11-03-2008, 12:25 PM
bpounds's Avatar
bpounds
bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
In an '05 XLT, I don't think keyless entry was standard. You had to order the advanced security group. Not positive, but I think that is true.
You do not have a chip in your key. That much is certain.
I suggest you request a build sheet from Ford and it will show you if you have the advanced security group.
Old 11-03-2008, 12:38 PM
wiingnut's Avatar
wiingnut
wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
bpounds info is correct
Old 11-03-2008, 12:57 PM
edd9000
edd9000 is offline
Thanks for the info.
edd
Old 11-03-2008, 01:39 PM
edd9000
edd9000 is offline
This is from the build sheet:
INSTALLED OPTION INFORMATION:
Air Conditioning: T/B - MANUAL AIR CONDITIONER GVW Code:
Alternator Amp Rating: 5A GVW Class Code: S
Audio Disk: * - [N/A] Instrumentation: * - [N/A]
Axle Ratio: EGAJB - 3.73 FINAL DRIVE RATIO Mirror(Driver Side): AQ - DRIVER PADDLE FOLD AWAY MIRROR
Axle Type: EGJAB - NON-LIMITED SLIP REAR AXLE Mirror(Psngr Side): * - [N/A]
Battery Amp Rating: AA Paint: PNKLW - TRUE BLUE CC WB
Brake Code: FBAAH -POWR 4-WHEEL DISC VACUUM BOOST Power Antenna: * - [N/A]
Brake Code(Service): * -[N/A] Radio: AU - ELETR PREM AM/FM STRO/DISC
Calibration Code: 5F714N0A Sound System: * -[N/A]
Color(Accent): * - [N/A] Suspn Tandem Axle:
Color(Trim): 000N5 - DARK FLINT Tire Brand: AK - PIRELLI
Delivery Type: 4 Tire Size: D3KCB - LT265/70/R17E A/S OWL
Driveshaft Code: * Traction Control: * - [N/A]
Front Seat: T/S - SEATS - INDIVIDUAL 40/20/40 Wheel Base:
Fuel Type: AF -UNLEADED FUEL CAPABILITY
No keyless entry that i can see.
edd
Old 11-03-2008, 01:52 PM
bpounds's Avatar
bpounds
2 bit Californian
Nope, I don't think you have it.
Old 11-04-2008, 01:11 PM
madjak's Avatar
madjak
madjak is offline
madjak is starting off with a positive reputation.
Welcome to FTE!
Enjoy your new ride.......the best truck on the road!
The SD's did not offer chipped keys until the 08 model.
Old 11-04-2008, 03:58 PM
riggz's Avatar
riggz
riggz is offline
On my 04 build sheet there is no Advanced Security Group. Only "Security Lock Group". I do have the remote keyless entry and door keypad.
Old 11-04-2008, 04:05 PM
edd9000
edd9000 is offline
I dont have a door keypad.
edd
Old 11-04-2008, 07:22 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
My 06 XLT doesnt have keyless. I installed a viper setup. My build sheet looked alot different then the one you posted. it actually said "keyless entry delete"
Soccer85
04-05-2015 11:02 PM
fordguy2236
1997 - 2003 F150
07-13-2013 10:49 PM
drejw2
07-23-2010 11:52 AM
GATRUCK
Electrical Systems/Wiring
08-20-2006 11:22 PM
DiamondF350
10-15-2001 02:55 AM
Quick Reply: Should my F-250 have keyless entry?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
