94 Powerstroke Cold Blooded All Of Sudden
I have a 94 PSD 170k miles. It starts right up and I can drive about a mile and it looses power and throttle response. It smokes like crazy and the RPM's will not come up. After 5 to 10 mins. it will clear up and run fine. If I plug it in or let it idle for 10 min (warm up) I don't have this problem. This is happenning when it is 4o degrees out. I 've owned this truck for 12 years and never had this kind of problem at this temperature. Any help is appreciated.
Sounds like Glow plugs or possibly injector o-rings. I have been having similar problems with this new to me truck that I recently accuired. Have you checked the glow plugs or any of the wiring connectors at the valve cover gaskets? All of the Powerstroke diesels I have owned have burnt the wiring connectors to the valve covers when a Glowplug has shorted out. Also if it is Glow plugs make sure to use factory Ford or Navistar only, the other brands have too many problems to list. I'm sure one of the many gurus around here can give you much more technical info than I am able to. Good Luck
Justin
Justin
I thought I had it after reading the dieselman's page. No luck. It has been cold more consistantly now and the problem still exists. The part that puzzles me is, will start up and I can drive it for a mile and then it shows the symtoms from above. Any ideas? Like I said I have owned this truck for 12 years and have been through most of the normal problems in this forum. I have used the search and cannot find one where the truck starts ok then exibits symtoms similar to a hard starting issue. By the way no check engine light so no codes.
How long has it been since you changed your fuel filter and cleaned your FPR screen?
I was having those same symptoms, although not so bad. It would start fine, run for a mile then start to miss just slightly for about a mile and clear up. Changing the filter and cleaning the screen made it go away.
Thank you Jim, I disconnected the correct plug. The valve shows open right now (truck has been sitting over night). Can the valve close any other way with it unplugged. New fuel filter. I hate to say it but I have never cleaned the FPR screen. Not really leaning that way because this is definetly a temperature related issue. No problems all summer.
Fuel is fresh. The problem existing through several tanks. And goes away as soon as it warms up outside. I have never added anything to the fuel in 12 years. Maybe the newer low sulfer diesel needs it more? If I can't fix it by the end of the day tommorrow I'm going to have to take it to the dealer for the first time ever. Consistant cold weather coming.
