Still Cranks But Won't Start
Hi guys! Happy Hollowen. Thanks for the help on my 01 psd however I have tried what you have recommened but it still cranks and won't start. Any other ideas???
I pulled codes today with a friends generic scanner and it said no codes found. I charged batts to make sure I had 10.5 volts required by the injectors. The truck has been in a heated building all day. I check the fuel filter. Changed the CPS. Not sure what else it could be.
Anyone have any ideas of what else to try?
Thanks Matt
'01 7.3 F350 6 speed XLT 78,000miles all stock
Thanks Matt
I agree with Lost. Check your CPS first. If that doesnt work then my money is on the IPR. There are high pressure orings on it that help route fuel to the injectors. Without these orings or one bein split they get no oil which meens no fuel. It is located on the back side of the HPOP on the drivers side. Should be almost right in front of the Fuel Bowl.
