Need some help with '71 rear end and brake info...
Steve - yeah, that's kinda what I was thinking, that I might have a 70, but the casting has the 60 on it. Someplace along the line, someone just put on 3" shoes instead of 2 1/2" ones. But, the upside is, the drums, if within tolerance, won't need turning - they are worn evenly across the 2 15/16" depth! Every dark cloud has a silver lining...
R
R
I haven't been able to find this anywhere...is there someplace? I can't understand why they would have 3" brakes, while the drums are only 2 15/16" deep. It makes them rub on the one edge, and hang out 1/16" past the drum on the other. Can't see that happening...were the drums different?
R
R
He sent me all the info. The rear axle he has is a Dana 60 (DOTA-BJ = 3.73-1).
The drum surface width is 2 15/16" wide, this is the size that uses 2 1/2" wide brake shoes
What we found was some goofball installed 3" wide brake shoes into the F250's drums.
Ford_Six: No F250, Camper Special or otherwise, came with 3" brakes.
There is not one application in the parts catalogs that show 3" brakes on any F250. Not 1953/72, not 1973/79.
Only 1967/79 F350's with Dana 70's came with 3" brakes (rear only after 1972).
1966/72 F250 Camper Specials all came with 12" X 2 1/2" brakes front & rear as part of the C/S package.
1965 F250 Camper Specials came with 12 1/8" x 2" brakes, as this was the only size available.
These same 12 1/8" x 2" brakes were used on non Camper Specials, 1966 thru 1972.
Originally Posted by rcav80r
Were the drums different?
Here are the specs again, with the Ford part numbers.
D1TZ-1126-D .. Rear Brake Drum / Fits: 1967/72 F350 with 12" x 3" rear brakes / Brake shoe surface width: 3 9/64"
D1UZ-1126-B .. Rear Brake Drum / Fits: 1966/72 F250 with 12" x 2 1/2" rear brakes / Brake shoe surface width: 2 15/16"
D1TZ-1126-A .. Rear Brake Drum / Fits: 1965/72 F250 with 12 1/8" x 2" rear brakes / Brake shoe surface width: 2 5/32"
12 1/8" x 2" rear brakes = the width of the rear drum is: 3 5/16"
12 x 2 1/2" rear brakes = the width of the rear drum is: 4 5/16"
1966/72 F250: Whatever the rear brake shoe size is, the front will be the same, and vice versa, unless disc brakes [optional on all '68/72 2WD models] are present.
Wish I could describe it better - I have a picture at home, but I'm at work. I'll try to post it tonight when I get home after midnight. It's the 2 1/2" ones. You 'll be able to see how it looks a "little" funny, compared to what most other cars/trucks look like.
Also, you can go to NAPA (napaonline.com), submit 1971 F250, and look up the rear brake drums - they have them listed for both 2 and 2 1/2" brakes. They have pictures of both flavors. Probably the easiest way. At least, then all you have to pull is a tire...
R
NumberDummy: yes, it's a '70, thanks again for the info.
rcav8or: Thank you for the pic. My initial impression is that I have the narrower brakes. I swapped a front tire last week and I don't recall seeing the taper as it's shown in your pic, but I wasn't paying attention at that time! I'll look at the NAPA site and compare when I take the spare tire off and put the regular one back on. I think I'll wait till the temps are out of the 30's with rain.
51dueller
02-17-2013 09:10 PM
Goliath1975
24
09-16-2011 08:59 AM
B.Ruddick
23
05-15-2009 11:58 AM
