Taller tire that will fit
I run 295/70/17 on a stock 2005 truck and have no issues with clearance. Unless you have a diesel, there shouldn't be an issue, and I don't know Norcal, do you have a diesel? The reason I say this, just so no one gets bent out of shape, is that a friend and I bought the same trucks (2005 CC, same options), his with a diesel and mine with a gas engine. His is an F350, mine an F250. His sat one inch lower in the front and one inch higher in the rear, so based on my measurements, the diesel sits about one inch lower in the front than a similar gas truck.
I had one issue with clearance. I have mud flaps on the front fender and while driving in slushy snow it built up and and became pretty hard (made like a big frozen snow ball behind the tire). When I tried to turn, the tires had to break off the almost frozen snow/ice, so it took a second of hard steering to break it and I had to drive straight (weird circumstance that wouldn't happen without the mud flaps). I've had my truck offroad, but not on a "Jeep trail" and don't get it "twisted up" while offroad, at least not very much. I haven't had any issues with rubbing anything. Senix, was your truck a gas or diesel?
