Engine noise on cold start
Old Oct 29, 2008 | 10:12 PM
kboughton's Avatar
kboughton
I have a 2005 5.4L, and when I start it the morning I hear something grind on the passenger side under the hood. The grind happens (1 second) when the heater cuts in, if I have the dial in the off position and then turn it on a couple of minutes later it grinds as soon as I turn the dial to defrost. I can't repeat the noise after the vehicle is warm. Any suggestions??
Old Oct 30, 2008 | 12:16 PM
Fishin76's Avatar
Fishin76
sounds like the blower fan is about to lose its bearings.
Old Oct 30, 2008 | 01:23 PM
jstnromero's Avatar
jstnromero
or the clutch is going bad...just a thought
Old Oct 30, 2008 | 03:02 PM
Fishin76's Avatar
Fishin76
No, not the engine fan, the AC blower fan. Now it could be the AC compresor clutch. that could be going bad.
My bet is still the blower fan......
Old Oct 30, 2008 | 07:57 PM
kboughton's Avatar
kboughton
I explained the noise to a Friend of mine who works at the local Ford dealership and he thinks that it is the AC compressor clutch when it cuts in (I only described the noise for him, he didn't hear it) He claims that it is common for it to make this noise and says that sometimes it will be worse depending on how long the truck has sat for. Has anyone else experienced this or heard anything about this being a common problem?
Old Oct 30, 2008 | 08:19 PM
Lead Head's Avatar
Lead Head
Placing bets on compressor clutch. Most modern vehicles are configured to kick the compressor when in defrost mode.
Old Oct 31, 2008 | 04:17 AM
yellowboy's Avatar
yellowboy
I have something similar on my 07 King Ranch. I usually leave the temperature the "Auto" mode so I'll have to pay more attention to what is causing it.
