Wheel and tire question
Old 03-01-2022, 08:18 AM
79Camper Special's Avatar
79Camper Special
79Camper Special is offline
Hello all,First time posting been on here a little bit.
I have the 16.5x6.75 Wheels on my Camper special,I’m trying to locate some wider steel wheels and that will Accommodate stock center cap that’s real important.Looking to get a more Beefed up look on the tires,ones I have now are just too skinny for my likings,Have the 8.75x16.5 Transforce on them now.I do have F350 Dual piston calipers up front as I found that out when I replaced the old ones,so not sure a 16inch rim will work on that,Hard to find a 17inch steel wheel with all the specs for this truck and that will take the original center cap. Thanks I look forward to some feedback.
Old 03-01-2022, 08:39 AM
440 sixpack's Avatar
440 sixpack
440 sixpack is offline
Received 1,530 Likes on 1,124 Posts
You can find original 16x7 wheels from 80's-early 90's Ford pickups and vans but be sure you get the older ones with the hub cap nubs. or several outfits make reproduction steel wheels in whatever width you want. Summit or Coker carry them.
With a 16x7 you can run as wide as a 285/ 75-16 tire. this is a picture of a stock 16x7 and a 285.
Old 03-01-2022, 05:35 PM
79Camper Special
I sure do appreciate that info,Gnna get some new Variable rate Moog springs I’m sure them originals are wore out by now. Thanks
CodaMan
1999 to 2016 Super Duty
10-28-2016 02:11 PM
fordboy300
15
12-24-2012 12:49 PM
K2JJB
12-04-2004 08:13 PM
RedTaurus94
05-30-2004 10:38 PM
TheMachfather
01-13-2004 12:04 AM
Quick Reply: Wheel and tire question
