NEW MEMBER Introduction Thread (NO TECH QUESTIONS)
Welcome to FTE
Well Stojan keep your chin up I'm sure if you're in need of reliable info someone here at FTE can help you out and one thing I have found really helpful is looking thru the post's and threads pertaining to my rig and then when i find my problem or something simulear jump in. as you can see i can't spell,but good luck. Brian W.
First Ford F250SD ...greetings!
Bought a used F250 as a Hooptie! (won't use for daily driver till I repair worn front end parts...steering and clunking noises)
Needs TLC and I will much appreciate any links, recommended parts vendors and tips on repair!
-have to rebuild front end (ball joints, tie rods, links, seals, brakes)
-cosmetics (aka rust) like body work, replace bed with take-off from another, ...
Glad to be a part of FTE!
Welcome Calvin nice score. Best of luck with the truck.
New here and just bought a 2013 F250 SCab XLT gasser for a tow vehicle. It is bi-fuel with a 23gal CNG tank. The CNG works well and I get about the same mileage. The only issue is the factory nerf mounts are corroded and it has spread some surface corrosion to the body seam. Looking forward to a trip with the TT to Moab and the Grand Canyon in September.
New Member in Albuquerque
Hello,
I just signed up to this site as I've just purchased a 1940 Ford COE which had previously been restored. I'm looking forward to meeting some fellow members with similar interests and look forward to your advise and resources. This is my first antique vehicle so I'm sure to have a lot of questions.
Many Thanks,
Howard
Many Thanks,
Howard
1992 F350 Dually / Boat hauler
Good afternoon everyone, been along time since i have been on the site. Love my old truck, used mostly to haul my boat around(28FT bayliner ) every once in a while have some problems. I reside in Ontario California, currently working on the Rams Chargers stadium in Inglewood Ca.
Keep on Trucking
Keep on Trucking
New to me F250 SuperDuty
2007 F250 6.0L SuperCab FX4 - Build Date 10/06, Color LD/Z3 currently 73K on the clock.
Not new to the forum as I have a 1991 F250 5.8L but just jumped right into the diesel deep end with this 6.0L largely because of VALUE and the 5.8L struggling to pull my RV. (think I solve that problem)
Truck is in the mid-Atlantic and was former 1-Owner NJ truck paid 18K
I have a 2000 F-350 single wheel crew cab long wheel base 7.3L close to 272xxx miles has been a work horse with just the usual sensor problems IPR, CPS, Map sensor, range sensor, torque bolts on the steering coupling, outside of that it has been a dependable, great truck!
I have had it a very long time and plan on keeping it till it dies or I die.
