Its all done and in
Old 10-28-2008, 11:25 AM
87 F-150 I6's Avatar
87 F-150 I6
87 F-150 I6 is offline
87 F-150 I6 has a good reputation on FTE.87 F-150 I6 has a good reputation on FTE.
Its all done and in
Wanted to post that I Installed my SS HPX and greased my drivers side front hub assembly last night. The hub grease had some dirt and sand in it, but not as much as the passengers side. The HPX install could not have been easier! I checked for leaks last night and did not find any. I also have noticed that the engine knock has quieted down some, thanks for all the info and help provided so far!
Old 10-28-2008, 11:27 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
Good job Andrew. Your truck's coming right along.
Old 10-28-2008, 11:30 AM
87 F-150 I6
Thanks Chris, also forgot to add that I tightened down the boot clamps. Some were pretty loose.
Old 10-28-2008, 11:33 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Make sure to keep the stock plugs and O-rings for the HPX ports in your glove box, I've heard way too many horror stories about them blowing which is why I haven't (and probably won't) done this mod.
Old 10-28-2008, 11:37 AM
03_PSD
03_PSD is offline
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
good job on the install Andrew!
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Andrew,
Good job getting some things done.
Just how much torque did you apply to the HPX bosses? Just curious.
Old 10-28-2008, 11:43 AM
preppypyro's Avatar
preppypyro
preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
Good job man!
I should do my hubs one of these days before the snow falls too, Ive been putting it off for awhile.
Old 10-28-2008, 11:56 AM
87 F-150 I6
Originally Posted by PaysonPSD View Post
Andrew,
I did not use a torque wrench. You could definitely feel when it was tight. I pushed past that point a little to snug it up, but it was noticeable. I wish I would have gotten some torque readings thought so we could file it away. I like doing things by the book and I am sure others do too.
Old 10-28-2008, 12:08 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
I haven't heard of ANY blowing. Stock HP oil lines, yes, but never the SS HPX! Mine leaked because I was too chicken to torque it down too hard, but once I put in the new O-ring and torqued it down, it's been fine for over a year now. Look at it this way -- there are already HP oil lines in your truck between the HPOP & heads. One more isn't anything to worry about, espeicially if you go SS.
Old 10-28-2008, 12:20 PM
PwerStroke99's Avatar
PwerStroke99
PwerStroke99 is offline
PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.PwerStroke99 has a very good reputation on FTE.
Chase i have had this mod for about 4+ years now and not have i had a problem. I did have some slight leaking when i have the steal braided line, but then upgraded to the SS line from KCm and i am absolutely happy with it. there is nothing wrong with this mod. i dont ever worry about it blowing out.
Old 10-28-2008, 03:17 PM
Pocket
Pocket is offline
Pocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputationPocket has a superb reputation
I also used to have the braided hose, and mine eventually developed a leak. Switched to the SS one and no problems since. It regularly sees over 3800 psi of oil in there.
Old 10-28-2008, 03:28 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Congrats on the new mods dude
A/Ox4
10-23-2013 04:23 PM
deerslayer165
05-20-2010 10:37 AM
gasgrunt88
60
07-13-2009 09:26 AM
rivrrunner
05-30-2008 07:05 PM
94xcabpsd
10-26-2004 08:07 PM
Quick Reply: Its all done and in
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
