Persistant ECT Code 117
Old Oct 22, 2008 | 06:48 PM
Peter94's Avatar
Peter94
Just an FYI. At my school, I'm being taught that instead of taking a resistance reading, a voltage drop reading is more accurate. So instead of disconnecting the PCM and the ECT and doing a resistance reading, you should leave them connected, turn the meter to volts, and backprobe the wire at the the ECT, and backprobe at the PCM, the reading should be around 0 volts, a reading larger than 0 (say 2 volts) would indicate there is a voltage drop in the wire.
Old Oct 22, 2008 | 06:49 PM
77300i6's Avatar
77300i6
Well, I drove the truck home from work (33 miles) and not once did the CEL light or did the truck try to stall.
When I got home I checked for codes, just to be doubly sure. All good.
I'm not sure if it was corrosion on the PCM pins or the bolt holding the connector in being loose, but issue seems to be resolved now. When I pulled the PCM connector, there was some whitish pasty stuff on the pins. The brake cleaner washed it off.
Thanks for your help pawpaw & R031Kona!
Old Oct 22, 2008 | 06:51 PM
77300i6's Avatar
77300i6
Good to know.
Peter94's Avatar
Peter94
I think the white pasty stuff is a corrosion inhibitor that is put on the connector from the factory.
Old Oct 22, 2008 | 06:54 PM
Peter94's Avatar
Peter94
Also on this note, there must be power running through the circut when doing this. You wont get a reading if there is no current flowing through the circut, so in your case it should be done with the engine running. Or if you are doing voltage drop tests on a battery terminal, you should have the headlights on, or any other load that would make power flow through the battery terminal.
Old Oct 22, 2008 | 06:55 PM
77300i6's Avatar
77300i6
That is what I thought too, but wasn't sure. Other than that, the pins/sockets looked fine.
Thanks for the tips Peter94
Mountain54
Mar 7, 2017 04:38 PM
AGrayson84
2004 - 2008 F150
Nov 7, 2016 09:24 PM
DBGrif91
Jul 26, 2016 07:26 PM
neal2ross
16
Apr 6, 2016 08:11 PM
bigjd
Jan 18, 2016 01:48 PM
