Coil Springs F-150 4X4
I just had a 3 inch body lift and new coil springs that are 2 inches taller than the old springs and new 33 X 12.50 tires installed on my 95 F-150 4X4. I went to get it aligned and they told me that they couldn't align it because I needed to get different axle beam drop down pivot brackets. The place that done the work doesn't have them!! Does anybody know where I can get these at. I have checked locally with no luck!!!! Thanks for any info!!!!!!!!!
Larry
Larry
If the drop down brakets are required they sould have came with your lift kit. I would check with a differant allignment shop, or make the company that installed the lift get it alligned correctly, this should have been done by the people who installed the lift anyway. what brand of lift was installed?
mountainair1
02-18-2010 09:15 AM
84ford460
02-09-2004 11:21 AM
