6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Engine Oil 3 Quarts Over Full. HELP
Old 10-20-2008, 01:31 AM
benmiller08's Avatar
benmiller08
benmiller08 is offline
I just recently switched from Rotella oil to Motorcraft oil and didn't notice till 500 miles later that they come in 5 qts and not 4. As a result I had been running 3 qts over the max. I am worried that I may have caused engine damage. Could someone please give me their opinion.
Old 10-20-2008, 06:42 AM
BowTieHatr's Avatar
BowTieHatr
BowTieHatr is offline
do you notice any engine vibration? if not drive it. if you are not comfortable driving it the way it is, drain some out.
Old 10-20-2008, 06:58 AM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
I wouldn't worry about it, heck, there are a lot of 6.4s running over full when they push diesel into the oil system so i'd think that 3 extra isn't a huge issue. Just drain it out a bit and go from there.
Old 10-20-2008, 07:10 AM
m350's Avatar
m350
m350 is offline
Dont these engines take 14 to 15 qts of oil anyway ? I know my 6.0 engine takes like 14.5 qts,,,If you have driven it 500 miles already,,and have not had any issues,,Just check things out,,,prob ok!
Old 10-20-2008, 07:26 AM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
6.4 is 15 including the filter, I will drain some off.
Old 10-20-2008, 01:56 PM
benmiller08
Yeah I drained it out as soon as i noticed but was worried about the effect it may have had. Truck drives fine and haven't noticed any leaks or other problems.
Old 10-20-2008, 02:16 PM
jasfaa's Avatar
jasfaa
jasfaa is offline
your probably fine if you did not notice any major vibrations. Did you check your dipstick after draining some off?
Old 10-20-2008, 02:29 PM
benmiller08
Yeah the dipstick level is at the top of the hashmarks.
Old 10-20-2008, 02:37 PM
benmiller08
Actually the whole reason I overfilled it in the first place is that my dipstick readings are never really clear. Usually I put in exactly the 15 quarts and my dipstick shows overfull. That is why this past oil change I thought nothing of it.
Old 10-20-2008, 02:51 PM
jasfaa's Avatar
jasfaa
jasfaa is offline
I agree but usually it is before you run it and refill the filter and injectors. Thanks, I was just making sure.
Old 10-21-2008, 07:37 AM
69cj's Avatar
69cj
69cj is offline
Install a Fumoto drain valve next oil change. Makes oil changes and problems like this much easier to deal with!
Old 10-21-2008, 07:43 AM
RED DOG DADDY's Avatar
RED DOG DADDY
RED DOG DADDY is offline
If your really worried IM maxiumum 4x4 (the moderator) he answered other tech questions, if im correct he is a tech....chuck
Old 10-24-2008, 07:20 AM
m350's Avatar
m350
m350 is offline
I have the Fumoto drain valve on my 6.0,,,it does make the oil changes much easier !
dh_meyer
2009 - 2014 F150
18
06-01-2023 03:38 PM
Tractionless
03-14-2016 09:10 AM
pauleouellette
09-13-2015 10:46 PM
pickenspolitics
03-09-2015 08:48 PM
Mike-11
1997-2006 Expedition & Navigator
21
01-05-2015 06:38 PM
Quick Reply: Engine Oil 3 Quarts Over Full. HELP
