help with my f-650
f650 or f600/ is it a 4x4 ? or something off the vin code
hoody i have a 72 f 600 x uhaul my model vin code is 604 whats up no showing of f 650 in all my manuals / i still can get parts for it /but some items can be tricky md./hd. eng.330-360 v8s up /water pumps/intake manifolds /rads. are larger and different in dezign to light duty 100-350s est. plus my 330-360 has a forged crank in it a "racers dream "eng. wow a 65 hey iv'e got i of those to 65/ MERC-350 napco4x4 300/6 cyl.-dully dumper still runs great all org. 65/66 last of the heavy metal trucks /"more info on your truck be great
What are the first three digits of your trucks VIN?
The reason I ask is, Ford never offered an F650 back then.
If the VIN begins with F60 = F600.
As original: 1961/66: F100 / F250 / F350 / F500 / F600 / F700 / F750 / F800 / F850 / F950 / F1000.
hard to find vin.code no. bill [i have a super-rare /mercury 350 napco 4x4 dully /587-1 axle 10,000 g.v.w. /but my problem is the top of the vin plate starts with = 5813532L-201215-B won't go into [vin finder ? tried it with M-350 at the start ,no dice what give with the no.# +2 letters at the top ,i know the rest of the code .[iv'e never seen one like it .is it a early type vin or what !!
1966 and later Canadian produced trucks use the same VIN system US trucks do.
5 81 35 32 L - 210215-B
5 = 6 Cylinder Engine
81 = Conventional Cab
35 = M350
32 = 132" Wheelbase
L = Left Hand Drive
210215 = Numerical Sequence of Assembly = 1965
B = Gross Vehicle Weight Range = 6,100 lbs. thru 10,000 lbs.
I can decode the rest of the info on the plate also.
66 and up vin change to u.s.decode plate style
that was excellent bill thanks! the rest of vin plate reads it's self out in plain lingo mecanics can understand like me that's why my[ 67 merc cs. is diff. >READS F25YCA28100 /WB-131-M8-D81-6-AXLE-24 FULL FLOUTING 410 GEARS MADE IN OAKVILE ONT.>THANKS AGAIN TO BILL THAT WAS INFO.
F25 = F or M250
Y = 352 2V
C = Ontario Canada Assembly Plant
A28100 = Numerical Sequence of Assembly = 1967
131" Wheelbase
M8: M = Wimbledon White / 8 = Springtime Yellow
D81: D = Medium Beige Petticrush Vinyl & Medium Beige Leeds Pattern Woven Plastic // 81 = 81B Custom Cab
6 = ? No such thing as a 6 / Could be a G = MX Cruise-O-Matic
24 = Dana 60 / 4.10-1 / non Limited Slip / 5200 lb. Rear Axle Capacity
Y = 352 2V
131" Wheelbase
Ford Vin Code Change 66-up
THANKS AGAIN BILL !2 WALLA'S IN ONE DAY **WOW - YES G TYPE ERROR / WHEN I FIRST GOT THIS MERC HAD TO TUNE UP TRANS BANDS /CLUTCHES ECT. "G" IN MANUALS SAID C4 AUTO. NO SETTINGS UNDER TRANS ON THE SIDESO FIGURED CODE WAS OFF ON PLATE IT HAPPENS RIGHT! MAYBE FMX ANY-HOOT AFTER HUNTING THROUGH MY MEMORY BANK CHECKED INSIDE CAB UNDER THE HUMP AND RUG BINGO "SERVICE PLATE" SET HER UP AND GONE LIKE A ROCKET HA HA AND WITH YOUR EX>INFO SOLVED A 12 YR. ? AND BRAVO
THANKS AGAIN BILL! 2 WALLA'S IN ONE DAY **WOW - YES G TYPE ERROR / WHEN I FIRST GOT THIS MERC HAD TO TUNE UP TRANS BANDS /CLUTCHES ECT. "G" IN MANUALS SAID C4 AUTO. NO SETTINGS UNDER TRANS ON THE SIDE SO FIGURED CODE WAS OFF ON PLATE IT HAPPENS RIGHT! MAYBE FMX ANY-HOOT AFTER HUNTING THROUGH MY MEMORY BANK CHECKED INSIDE CAB UNDER THE HUMP AND RUG BINGO "SERVICE PLATE" SET HER UP AND GONE LIKE A ROCKET HA HA AND WITH YOUR EX>INFO SOLVED A 12 YR. ?AND BRAVO
Thru 1978 G refers to all A/T's used on F Series Trucks & Econolines.
C6 / C4 / MX & FX Cruise-O-Matics / FMX Cruise-O-Matic / 2 & 3 Speed Ford-O-Matics.
One has to know which trans was used with what engine.
No C4's were ever used with FE engines...not a one.
darthice
17
02-05-2024 10:36 AM
