Help under valve cover harness burnt.
This morning after leaving breakfast I statrted my 95 stock PSD and it fired up and after one or two second of running the engine light came on and the truck immediatly started running like it was only running on a few cylinders. It drove home but was very under powered. the engine light comes on a second or two after it is started. It runs fine for that first second or two. I put a code scanner on it and it would not pull any codes. the engine light only comes on when it is running. I started some research and came up with checking the under valve cover harnesses. the outer plugs on the passenger side had 1 pin in the front and one in the rear burnt up. The one closest to the front of the motor and the one closest to the rear of the motor. I replaced the burnt pins and put in new glowplugs in the passenger side of the motor. Now it is running worse. It does still run fine for the first second or two. I did not see if it is still burning the wires as it is now to dark and late.
Any ideas guys
Any ideas guys
Thanks
Hey I replaced the inner harnesses on the passenger side, the VC gasket, and the plugs on the passenger side. Drivers looks good. I picked up the only plugs I could find Autolite. Are they as bad as every one says. I will probably replace the other side plugs in a month or so and i guess I could throw down some more cash to get the autolites out if they are as bad as everyone says
Thanks for all the info
Keep on trukin
Keep on trukin
RubberDuck
42
06-19-2022 05:16 PM
Manofgod4life
02-02-2016 09:07 PM
Ford4Life7.3
08-15-2014 12:26 AM
Fuzzydog
75
10-31-2011 09:20 PM
