Looking for Tonneau input
Are any of you using the Rugged Cover triple fold tonneau cover? It looks pretty sturdy to me, but I'd love to have some feedback from folks that have used one.
I carry a large slide-in truck camper and cannot have any brackets or clamps left on the truck after the tonneau is removed, and the Rugged Cover meets that criteria. There are a few other competing models, but they are considerably more expensive.
Thanks.
Thanks.
i'm using the ford factory soft tonneau cover, there are 4 clamps that hold each side rail on. its takes 10-15 minutes tops to remove or install so i can load my truck camper. generally i don't find myself switching back and forth real often. once the camper is on it mostly stays on unless i need it off, of course it helps that it not really my daily driver at the moment. if i was loading the camper every weekend it would be kind of tedious to remove the tonneau.
I have an agri soft cover which roles up. the rails dont need to be removed to put in a camper. I am really happy with it, and its 4 years old, it has seen 80,000 Km and temps from -49 C to +43 C. Also, its waterproof enough to put soft luggage in the back and not worry about it, but roles up to load the truck. the rails would not interfere with a camper...
So, after doing a good bit of research, I rolled up the Ford cover and put it in the trash pile and bought the BakFlip HD G2 from RealTruck.com. The entire cover can be taken off without removing the rails and the rails are held on by 6 clamps just like the Ford cover.
If anyone has a F250 in the Northern VA area and wants the Ford cover, drop me a line to wsh (at) sprintmail.com. You can come get it for free.
Scott
