full flow oil filtering
I too am looking at converting my motor to full flow filtering. Motorcity flathead has a pretty neat kit but its kinda pricey. But then again so is an engine rebuild. My main reason for doing this is so I can also install an oil cooler as well as a good spin on filter. I belive it to be worth the money to convert to a full flow system in the long run if the vehicle in question will be driven with any reularity, as far as every now and again I guess its not as critical.
Ok, I know this is an old thread, but it came up when I did a search.
My engine guy is recomending a full flow filter and I want to use the existing filter to keep the stock look. His advice/reasoning is that the motor we are re-building had the oil ways in the crank completely plugged. His reasoning is that when you shut down the engine, any impurities in the oil will settle where they are, and stay there. With the old Flattie, only part of the oil goes through the filter and so your oil will always have stuff in it. I'm thinking especially with an occasional use vehicle this could be a bigger problem, rather than on a daily driver.
Has anyone had experience using the existing oil canister, and converting it to a full flow with a spin on filter?
Thanks in advance,
Steve
Thanks in advance,
Steve
I dont know about using the existing can, but I heard someone mention using the original filter can as a small on engine tool storage compartment that way you can leave it on there for the looks but mount the real filter somewhere else. Not sure what tools would actually fit in there though?
I am also thinking I want a full flow filter setup on my engine assuming I ever get it in for rebuilding.
Josh
Josh
well, might as well add my two cents--use my flattie almost every day. have a partial flow spin on filter (FOR EASE AND NEATNESS OF OIL CHANGE) connected to factory location. change oil three times a year and always clean. i'm not saying that oil doesn't get dark, cause it does, but it's not gritty or "fugly"! i also have a 3/4" magnet on oil drain plug-just in case. i definetly agree that full flow is BEST,but you can get away with partial. just keep clean oil in engine to prevent sludge buildup!
FWIW, (nothing) oil has come a long way over the last 60 years and I think modern oil, be it dino or synthetic, will not have the sludging or varnishing problems that older engines were subjected to. But.....do as you wish.
on
1 Post
Red's Headers has an install kit for not much money that is mainly a diagram on what to do to make the engine full flow. I did it on my 296" somewhat loaded engine and it works great. Not many miles but good oil pressure at all RPM's. Well worth the time and money because now every drop of oil is filtered.
Jim
Jim
RJthe84ranger
General Diesel Discussion
08-23-2016 04:46 PM
speakerfritz
6.4L Power Stroke Diesel
12-11-2015 08:42 AM
hillcountryflt
09-20-2015 09:37 PM
