Bendix seal kit
On the box, there would have been a tin tag attached on the top with a code for parts...like an HCE-G or similar...email or post the tags code info as in looking at the parts list for the kit and looking at what I believe to be the steering gear pic arent totally making sense in my eyes...I just wanna be sure Im looking at the parts list for the correct steering gear.
Also, how many individual parts came in the kit you ordered from Green Sales.
- cs65
- cs65
I will get #'s off of metal tag. The kit has all seals with exception of the 4 white seals that go on the cylinder that slids on the worm gear shaft. I do not know what this part is called. In the Ford parts book (cd) it is illustration 2 section 35.1. Part #'s for seals (rings) is 3D771.
Thank You!
The seal kit from Greensales is complete. The parts I need are not included and Greensales dosn't stock them. Greensales has been helpful in the location and identification of parts!
Thank You!
Thank You!
Greensales has been helpful in the location and identification of parts! Uh huh...
I've dealt with Green Sales for 40 years, and while they are helpful, they did NOT help much here.
They could have given you the complete part number, and used the same FoMoCo locator system I did to find them for you.
Thank You!
The same Bendix P/S gearbox was used 1966/68, thru serial # G30,000 on 1969's.
Have the parts catalog? Look here: TEXT: Section 35.1 / Parts List # 45 / Pages 24 & 25.
4) C6TZ3D771A .. Ring-Worm Gear / 1 1/2" O.D.
Here are the only Ford dealers who still have stock. No obsolete parts dealer has any.
Found these on the Ford in-house parts locator system...
Bob Allen Ford in Overland Park KS has FOUR = 800-676-0675
Kinsel L/M in Beaumont TX has FOUR = 800-816-2894
Griesel Motor Co. in Okarche OK has FOUR. No # listed.
That's all she wrote.
I went looking at the illustration and was trying to makes heads or tails of the pic and from the description of what was needed and was left scratching my head...I, after seeing what the kit was called you got from Green thought that pup would have had every small replaceable part/seal that could be replaced...I was wrong
- cs65
- cs65
- cs65
- cs65
The master kit contained all the parts in those two kits and more.
While the parts catalog only has a partial list of the kit contents, I would think that those 4 parts would have been there.
The kit came in a paper envelope with a sticky flap, so it's EZ to seal it up again.
My guess is, someone needed the parts, robbed them from the kit, never replaced them...later on Green Sales bought the kit from a dealer, and because there's no listing of all the parts, didn't know they were missing.
I found two of these kits for other members here (may have found this one too...don't recall). Both of the previous two kits were bought from Green Sales.
I never heard a peep from the other two members inre to parts being missing, so draw your own conclusions.
bigcrunch
03-16-2016 07:08 PM
68fish
10-16-2015 07:53 AM
fzeed
06-21-2009 11:58 PM
76crewcab 4X4
11-27-2004 04:50 PM
