Converting From a 2G to a 3G Alternator
on
1 Post
Hi all, from what I have read the 3G alternator is a much better design then the older 2G style, I guess the 2G's have also been known to cause fires due to the two battery and stator connector aging. Well my 91 Ford has the 2G and I really do not like the funky two primary wire and stator connector. So I wonder if I could purchase a 3G alternator and install it on my truck. From what I can tell the only difference between the 2G and 3G mounting setup seems to be the alternator adjusting bracket for the 7.5 engine application? So what I would do is to purchase a new 3G alternator and regulator connector wire the regulator accordingly and make a new battery lead cable with a mega fuse. Is this correct or am I mistaken?
zoom38
39
03-30-2018 01:53 PM
MEvans043
05-09-2016 10:20 PM
Mad tiki
15
12-14-2015 10:08 AM
