15-w40 for fuel?
Old 11-18-2008, 08:02 AM
89ford73's Avatar
89ford73
89ford73 is offline
15-w40 for fuel?
i know where an endless supply of free 15w-40 engine oil is. question is can i burn it for fuel? should i heat it up before it goes into the motor? start on diesel, run on oil? mix it 50/50 and go. forget it and just change oil really often?
Old 11-18-2008, 11:54 AM
greenego's Avatar
greenego
greenego is offline
Just change oil really often.
Old 11-20-2008, 10:50 PM
starmilt's Avatar
starmilt
starmilt is offline
worth it to heat your shop with it.
Old 11-21-2008, 07:36 AM
89ford73's Avatar
89ford73
89ford73 is offline
i heat my shop with used motor oil. lol, got plenty of that on hand. cant get rid of it all winter
Old 11-25-2008, 08:00 PM
jhess's Avatar
jhess
jhess is offline
Waste motor oil
Yes you can use it as fuel. Start at a lower mix about 20% move up slow with each tank and see how much your truck likes. I was burning 80% with no problems on 6.4 2008. I also had to do the SCT DP delete so as not to clog it. Now when outside air temps. are getting colder I have to mix 50%. I have been doing it for 20K miles.
Now as for lubercation add 2 stoke oil. I use 2 cups for 10gal and acidtone to help with the burn.
Old 11-26-2008, 07:31 AM
89ford73's Avatar
89ford73
89ford73 is offline
how much acitone per 10 gal? and if you get too much does it become a problem with cold temps. it never gets below freezing here so im probly okay
Old 11-26-2008, 07:38 AM
89ford73's Avatar
89ford73
89ford73 is offline
how much acitone per 10 gal? and if you get too much does it become a problem with cold temps. it never gets below freezing here so im probly okay and would there be any difference between using new motor oil and used motor oil. because i can get all the fresh motor oil i want.
Old 11-26-2008, 06:10 PM
jhess's Avatar
jhess
jhess is offline
waste motor oil
It has beed said that 1 to 3 OZ for 10 gals is good but no more. If you put too much in your tank than your MPG will start to fall off. Also I forgot to say that filtering is important, I filter to 5 microns and you can get new oil that will help going though the filter faster. I mix mine up in a 30 gal drum than add the diesel, 2 stroke oil and acidtone. From there it gets pump to the truck.
d-day
Bio-diesel, Propane & Alternative Diesel Engine Fuels
33
06-06-2016 09:14 PM
jed1894
34
11-19-2015 03:27 PM
66crawler
23
03-12-2013 07:30 AM
98woody
04-17-2012 12:06 PM
90pioneer
05-08-2011 09:00 PM
Quick Reply: 15-w40 for fuel?
