1997 F-350 trouble
1997 F-350 trouble
I ahve a 97 PSD that has a misfire when the pedal is pushed rapidly. Once the engine comes up to speed the mis goes away. It is noticable under load or not. I just installed a new mech fuel pump and cleaned the screen in the filter housing. What else may cause the mis? Do I need to check the hpop pressures? I have all the inj. o-rings and plan on installing them also. Would bad o-rings contribute to the miss or not? Thanks
Do you have excessive smoke when it starts to miss? Does it occur at idle or only when you get on it. Do you have a tuner? We need to know a little more information than what you provided.
Injector o-rings could be the problem. Usually when they start to go the engine will bog down at high rpms.. aka a ton of blue smoke will be generated. If you replacing the o-rings, it would be a good time to do the glow plugs as well.
It doesn't sound like a hpop issue to me if you have a stock engine.
Does it miss real bad when it is first started in the morning?
I just bought this truck last week, last night I noticed someone has blacked out the CEL with marker or something, I think. Is the CEL in the lower right side of the inst cluster?
No it runs alright in the morning, starts very hard, but once its running it does ok. Are you in Thunder Bay, Ontario?
Thats it!! Exactly what it does. I will be replacing those this afternoon. Thanks, Ryan
