How to Paint Door Panels?
Old 07-19-2014, 09:27 PM
KG Excursion's Avatar
KG Excursion
KG Excursion is offline
I have a 75 ranger xlt with the faux wood grain door panels.
I'd like to just paint the whole panel black.
Has anyone done this and if so, what is the best proces for this? What paint should I use?
Also, does anyone know a good source for the plastic clips that holds the panel to the door?
Old 07-19-2014, 09:37 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
I used Rustoleum "Paint for Plastic" in a Satin Black, it seems to be holding up great.
I washed the door panel off with soap and water, removing all dirt and scraping off any stuff, then let it dry. With a clean lint free rag, i quickly wiped it down with lacquer thinner. Then painted a few coats. The paint is available from Auto Zone and O'reillys.
I cleaned the rubber arm rest off too. Then made the mistake of wiping it off with lacquer thinner. Dont do it! It ate the rubber immediately. Then i painted it with a Duplicolor Vinyl and fabric paint.
The clips are readily available at your local parts store. I bought the ones for Ford, but others have used other ones and they say they may work better.
Old 07-19-2014, 11:18 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
These GM ones longer and have a bigger head. And a little velcro helps. Dremel out the 2 spots that hits the 2 bolts heads.
No worries that finger cup will hide it.
Old 07-19-2014, 11:32 PM
spikinfool05's Avatar
spikinfool05
spikinfool05 is offline
ya any good paint would work but why paint over the wood grain? someone is always looking for this style of door panel maybe do a trade or find a good set of just black panels and leave the the stockers alone if they are in good shape.
Old 07-20-2014, 07:59 AM
19-F250-78's Avatar
19-F250-78
19-F250-78 is offline
I'd buy the wood grain panels off you if you're just going to paint over it. Like spikinfool05 said, someone is always looking for that stuff.
Old 07-20-2014, 09:02 AM
NMFirstF2504X4's Avatar
NMFirstF2504X4
NMFirstF2504X4 is offline
As suggested previously, there are a number of good plastic/vinyl paints on the market. I think I got mine at Pepboys. Prep work is key - 30 years of grime in the textured surface took a lot of scrubbing to remove. Before painting, I used mineral spirits as final scrub to make sure there was no oil/dirt on the surface.
Old 07-20-2014, 10:16 AM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
Black panel
Sem products are real good,painted mine three years ago,looks like the day I did it,,cost more though.
Norma stitz
07-29-2017 05:59 PM
bsiebert
10-11-2010 06:09 PM
Dutch123
Paint & Bodywork
10-04-2007 07:41 PM
82Red
04-15-2004 11:35 AM
77hiboyboy
05-14-2003 07:55 PM
Quick Reply: How to Paint Door Panels?
