replacement of starter
ok I have a 81 f-150 with a straight 6. I replaced the fly wheel and but it back together and also had to replace the starter. It starts fine runs good but now I have a problem with the starter sounding like it does not ingage in sounds like it is always rinning with the fly wheele. I shimmed the starter and still does it. I am wondering what else it could be or is the starter could be messed up from the parts store I also replaced the silinoid too. please help me out.
if you bought a "remanufactured" starter, that is probably your problem. In a reman starter, they simply just replace what broke in the first place, and leave the rest. They are junk, I have never had any luck with the $29 dollar autozone starter. Although i do continue to purchase them, and soon realize i have made the same mistake over and over, and end up going back and buying a 100% new starter and doing the job twice. I guess i always htink im gonna have better luck lol So, if it is a reman starter that should be your problem. If it is not, then I am not sure. I have never had to shim a ford starter. Did you try it without the shim? I have seen chevys where the mount for the starter was cracked, and the start would wobble and and make all kinds of noise. But, i would say buy a NEW one if you havent already, and check to make sure it is tight. It is pretty hard to screw up the install of a ford starter, so i would say its a bad starter.
I get electrical parts here DB Electrical Starter-Alternator
Had real good luck with the parts,price is good,shipping is fast
Blake Phipps
43
07-25-2013 07:23 AM
dell
17
03-27-2006 11:42 AM
Hi Ho
18
07-22-2005 12:18 PM
