I need to replace my center support beadring on my 2 piece driveshaft. The new one comes with a 35mm or a 40 mm diameter. Without pulling off my driveshaft whow do I tell the difference?
ok I tried the mic method but could not get it in the right spot.
I found out that the 40mm is for a coupling type drive shaft and a 35mm is for the slip yoke style. I am 99% sure mine is the slip yoke style at that location .
