Sponsored by: Auxito
Could it be bad gas?
Old Oct 6, 2008 | 07:21 PM
triton54's Avatar
triton54
OK so thing morning i leave for work and its running fine. Found gas for $3.07 so i filled up (took 21 gal.) and it ran fine for the next 15 miles or so. Left work and i felt it start to faintly shutter and as i drove it just got worse to the point where it felt like i was running a jackhammer. It would kick in and have smooth spurts but mostly a shaky ride. I went and got some injector cleaner and dumped it in and i hope it helps. Can anyone think of anything that would noticeably ease its way in like this did besides the bad gas circulating through? Its a 97 250-5.4-4x4. I hope its the gas because this thing is killing me already.
Old Oct 6, 2008 | 08:25 PM
steve(ill)'s Avatar
steve(ill)
put some extra injector cleaner or if they sell 85% ethanol, get 2 gallons and add that. in Illinois we have 15% ethanol (about 3 gallons in a 20 gallon fillup) in the standard gas. that absorbs any water and keeps injectors clean. works good.
if that dont clear it up in 20-30 miles, then i would look for a code. maybe you have a COP failure or plug failure and its just a concidence. How old are the plugs?
Old Oct 6, 2008 | 08:32 PM
triton54's Avatar
triton54
I put 2 bottle of cleaner in it and its a 25 miles commute to work so i hope it works. The plugs however, I won't lie, have been neglected since i got it about 3 years ago and i would assume for quite some time prior to. Good weekend project i guess to change them regardless the outcome of the cleaner it sure couldn't hurt. No CEL btw due to it being burnt out so it may be on...but not on.
Old Oct 7, 2008 | 06:41 AM
Ron W.'s Avatar
Ron W.
First thought, draw a code. First guess you have a COP or plug going out.
Old Oct 7, 2008 | 03:06 PM
tvenney's Avatar
tvenney
I had the same thing happen to me. I had to replace the Fuel pressure regulator.
