Offroad & 4x4
Danna 44 TTB
Old 06-26-2001, 01:52 PM
burton's Avatar
burton
burton is offline
Danna 44 TTB
How do i get the right axel out of the Danna 44 TTB? It is in an 81 F150. Thanks for any suggestions.
Joe
Old 06-26-2001, 08:55 PM
billyb's Avatar
billyb
billyb is offline
Danna 44 TTB
you have to open the pumpkin and remove the c-clip.
Old 06-26-2001, 11:59 PM
burton's Avatar
burton
burton is offline
Danna 44 TTB
There is a slip shaft on that side befor the axel goes into the diff. Should the axel simpily pull out of the slip shaft? Because I can't get it to.
Thanks
Joe
Old 06-27-2001, 02:37 PM
84w44s's Avatar
84w44s
84w44s is offline
Danna 44 TTB
[font size="1" color="#FF0000"]LAST EDITED ON 27-Jun-01 AT 03:38 PM (EST)[/font][p]yes, the slip shaft's should separate. it may take a little work, but they will come apart.
Old 06-27-2001, 03:46 PM
burton's Avatar
burton
burton is offline
Danna 44 TTB
Well I opened the diff and I can't find the C clip. So how the h**l do i get that axel out?
Joe
Old 06-28-2001, 07:49 AM
billyb's Avatar
billyb
billyb is offline
Danna 44 TTB
sorry burton,
you have to remove the bolts that hold the bearing retainer to the side of the housing. you can then slide the stub out. hope this helps.
Old 06-28-2001, 04:06 PM
burton's Avatar
burton
burton is offline
Danna 44 TTB
Well I finally got the damm thing out. I had to get a bolt that threaded into the end of the axel shaft and attach a slide hammer to it to get the slip shaft apart. Those things are great. Then I had to hammer the stub shaft out. What a pain. That stupid bearing is pressed onto the axel keeping me from replacing the little seal. Guess I will have to take it to the shop.
Thanks a lot guys,
Joe
Old 06-30-2001, 10:40 AM
85351ho's Avatar
85351ho
85351ho is offline
Danna 44 TTB
hansen
17
05-14-2009 10:45 PM
96f250in253
09-19-2008 12:49 PM
rswhitmore
10-19-2007 01:38 PM
s_floater
Minnesota Chapter
03-06-2006 05:30 PM
390GT
05-14-2000 04:15 PM
Quick Reply: Danna 44 TTB
