Exhaust shop in NH
Exhaust shop in NH
Does anyone know of a good exhaust shop in NH???
I cannot seem to find one and i just recently had Meineke do a custom exhaust (14" Magnaflow SI/DO) for me because of lack of choices. I want to find a shop that will use Stainless steel tubing with Mandrel bends and at the same time not rape me on the price. Meineke used aluminized tubing, the bends are smooth but there is diameter loss in the turns which is bothering me. Also the tips are slighty off (not by much though), they are not quite even on each side of the truck. Maybe it's a little **** of me to want the tips in the same EXACT spot on each side, but that's just how i am. I'd assume a little measuring could of prevented this.
So if anyone knows of a quality shop to have my exhaust fixed up the way i want it, please let me know.
Thanks.
Thanks.
Thanks.
Thanks.
If you are close to MA there are a couple in Lawrence..
Lou's is one and Auto ER is the other..
There are a couple of Lou's custom exhaust shops in the area..
Hey Don, i'm located in Manchester. So the Lou's down there will do Mandrel bending and stainless steel? I called Lou's up here in manchester and they said they don't do Mandrel Bending, at least not up here.
That's my main concern is i want the tubing to actually be Mandrel bent and stainless steel, not crush bent, or the so called smooth bent which is what i have now. The smooth bent seems to decrease the diameter of the tubing on the turns.
I'll have to check them out, and the other place you mentioned as well.
Thanks, Dan.
Thanks, Dan.
Thanks, Dan.
Thanks, Dan.
I'm surprised that they don't do it at Lou's in Manchester.. That's part of a custom exhaust..
My son had an exhaust done at Lou's I will ask him if he thinks they do mandrel bending when he gets home..
Thanks, i'll give these guys a call as well.
Josh1767
07-02-2015 10:57 AM
Josh1767
06-30-2015 05:11 AM
