Vacuum Solenoid line tracing. 01 Expy.
Hiya friends.
Probably should read Vacuum solenoid/actuator line tracing.
Tracing vacuum lines from my dash control **** to the different solenoids or actuators under the dash.
Help identifying which line goes to what and for what. Make sense?
Red vac line goes to upper actuator in drivers side footwell. What does this one control?
Yellow and blue go to the lower actuator in drivers footwell. What does this one control?
Have no idea on the white and black. If they go to one or two actuators? Annnd what do those two control?
Hope this makes sense?
Could use a little schooling. Trying to learn the system a little bit.
Went to the junkyard today to tear into a couple of trucks.....it's how I learn what is what before testing into my rig and usually half the work I'd done for me at the J/y.
Thank you for the guidance as I track down a vacuum leak.
Drew
Drew
Hiya friends.
Drew
Drew
Black is the vacuum source.
Nathan Koeppe
03-22-2018 09:23 PM
gotjeepzj
16
03-06-2010 03:29 AM
