Truck running bad, not sure whats wrong it ! Please Help!
Hi, I have a 93 F-150 XLT, V8 w/ an anuto transmission.
Anyhow for the last couple years the truck has run pretty crappy, not exactly sure whats wrong with it or where to check.
What it does is when your sitting at a light, and if you give very little gas the truck will want to stall, or it will stall. If it doesnt stall it will stumble pretty badly at times.
Basically I have to hang back let traffic go so I can give it enough gas from a stop light to keep it from acting up.
A check engine light is on, I took it to autozone and had them scan it and it came up with an EGR code, from what I have seen and read a EGR code should not effect performance so I am not sure where to look. I have changed the plugs and wires and nothing has changed at all.
Any suggestions on where to look would be appreciated.
Thanks
Rich
Thanks
Rich
jeffg123
05-10-2009 08:11 AM
rich gill
16
10-02-2008 07:57 AM
jakefreeman78
06-30-2008 12:21 PM
SportTracn02
08-17-2005 11:12 AM
